Finito the GTS 2009 2.4L TURBO tuning @ DynoCenter PR
Old Jul 28, 2009 | 06:23 AM
black cloud's Avatar
The project was good but i want to get to the 300whp but first I have to change the clutch!!!!!! any advise were i cand fine a kit for the 4B12??????
Here some vids!!!!!
http://www.youtube.com/watch?v=PcueEUfWjVs
http://www.youtube.com/watch?v=FTzONP-FnI4
http://www.youtube.com/watch?v=1doDYlr2qG4
Attached Thumbnails Finito the GTS 2009 2.4L TURBO tuning @ DynoCenter PR-dyno-grafic.jpg
Old Jul 28, 2009 | 06:44 AM
EngRWW33's Avatar
www.speedcorps.com
www.roadracemotorsports.com
Nice numbers too.
Old Jul 28, 2009 | 07:15 AM
Originally Posted by EngRWW33
Thanks!!!!
Old Jul 28, 2009 | 07:39 AM
EVO8904's Avatar
What turbo do you have? Nice numbers
Old Jul 28, 2009 | 09:27 AM
Turbotech's Avatar
Good luck bro! Ruben at dynocenter is the beast jeje Good numbers but you really need to change that clutch asap. 8lbs of boost and 240hp is really good for wath you have. Sigue pa lante bro!!
Old Jul 28, 2009 | 10:30 AM
Ralliart turbine with manifold..evoX fuel injectors, mass sensor and map sensor. wallbro 255 fuel pump...and 1lb alluminum crank pully....... stock internals.............
Old Jul 28, 2009 | 11:28 AM
EngRWW33's Avatar
you think the stock internals are ready for more boost? I would think 8 psi would be MAX without stronger internals...
Old Jul 28, 2009 | 12:20 PM
EVO8904's Avatar
Did you use a EVO X downpipe too? What about your FMIC?
Old Jul 28, 2009 | 04:56 PM
downpipe from Ralli///Art
Old Jul 29, 2009 | 05:56 AM
the4thpower3's Avatar
black cloud
Are you running the stock GTS plastic intake manifold?
What are using for tuning/engine (timing, fuel, mivec, etc) management?
Old Jul 29, 2009 | 08:01 AM
EVO8904's Avatar
I would try to get a differet intake manifold, maybe a EVO X or RA manifold would fit.
Old Jul 29, 2009 | 02:52 PM
eyekyu's Avatar
WOW
congrats def didnt expect that
Old Jul 29, 2009 | 07:03 PM
nunyas's Avatar
nice! What did you do for the ECU? Custom flash? swap for the Ralliart ECU?
Old Jul 29, 2009 | 10:11 PM
Turbotech's Avatar
He did a custom reflash by a local tuner here in PR.
Old Jul 30, 2009 | 11:30 AM
Originally Posted by the4thpower3
black cloud
Yes the car have the plastic mani.
