who knows what a variable load flasher is?
Old Nov 20, 2003 | 01:50 PM
TURBOit's Avatar
alright, well i got this Bright Red LED Turn Signals (1156), and it says some require a variable load flasher? i have no idea what it is or if i even need it, but these things look like they fit right in
Old Nov 20, 2003 | 02:09 PM
Sailorgoon's Avatar
I believe that prevents the LED from flashing so fast you can't even tell it's changing. I've been wrong before though.
Old Nov 20, 2003 | 02:12 PM
CromeOz's Avatar
i dont know ...just 2 let you know
Old Nov 20, 2003 | 02:23 PM
TURBOit's Avatar
heh, ill plug them in and see what happens when i get my car back, worst thatll happen is that the LED will bust, nothign else, because its 12 volts just like stock so yea, thanks ChromeOZ lol
Old Nov 20, 2003 | 03:31 PM
myoung's Avatar
It's a flasher that has an internal relay to cycle the flash period of the lights as opposed to a bi-metal spring like a regular flasher.
LED's don't draw the same amount of current that a regular filament bulb does, so with a regular flasher they would flash really slow or not at all.
Does the instructions say your particular car needs one, or just that you may need one. The lancer should already have relay controlled flaher timing.
Old Nov 20, 2003 | 04:06 PM
TURBOit's Avatar
it just says in some applications it may be needed
Old Nov 20, 2003 | 05:27 PM
myoung's Avatar
Just put 'em in and hit the turn signal, if they flash normal you're good to go.
Old Nov 20, 2003 | 06:04 PM
MalibuJack's Avatar
Hmm.. When I first read this I thought it was about a fat guy in a trench coat..
But most flashers rely on the load of the circuit to flash at a particular rate. LED lights draw less current then filament bulbs and probably wouldn't flash the flasher. From what I can tell, I don't think our cars make much of an audible click when the flasher is on. (some cars actually "Ding" because they have a relay and early studies said people wanted to hear the clicking as a reminder that they've left their directional on)
The good news is you can easily swap a standard flasher for a variable load (Solid state) flasher.. the bad news is if it made a clicking noise before, it may not make one after you swap it (or it will ding, dink, or not make any noise)
thuup8
Aug 1, 2017 10:55 AM
abrar
Jan 1, 2016 02:01 AM
Onkar02
Lancer Troubleshooting
Sep 11, 2009 12:16 AM
Jp7
Apr 14, 2008 01:15 AM
FullOutPwr
Mar 23, 2008 07:21 PM
