better get something to wipe that drool off..
Old Dec 7, 2003 | 10:52 PM
  #46
Iamkar33m's Avatar
gotta splice and dice some wires and do all sorts of fancy hookups.
Old Dec 7, 2003 | 11:25 PM
  #47
TeamNeXusOz's Avatar
i have had mine on for awhile now...with 10 fuses...no problems...why go with 20 tho...just a little curious?...brighter?...or does it even matter?...ummm...yeah...these head lights kick ***
Old Dec 7, 2003 | 11:28 PM
  #48
Iamkar33m's Avatar
let's just say if the power surges for some reason... and u have 10's (which barely cover the load on the lights)... then ur fuses will blow easily compared to if u have the 20 fuses.
Old Dec 7, 2003 | 11:33 PM
  #49
i have two 12's and two 500w (rms) amps in my car...no blown fuses...my interior lights dim once in awhile...whit my system turned all the way ...but never the head lights...
Old Dec 7, 2003 | 11:37 PM
  #50
Iamkar33m's Avatar
That's a different issue. The system is drawing power DIRECTLY off the battery (most systems do). The lights, however, go through the fusebox. Imagine the alternator gave off some sort of power surge which passes on to the battery and goes to the fusebox. The 10amp fuses will prolly short out easier than the 20amp fuses. U went from 1 bulb for hi/lo to 2 different bulbs... doubled the load on the wire/fuse. Which is why it is recommended to upgrade the fuses to 20's.
Old Dec 8, 2003 | 12:31 AM
  #51
ah...ic...
Old Dec 8, 2003 | 06:10 AM
  #52
majestic lancer's Avatar
you just simply pull out the 10amp fuses and just replace them with the 20's? is it as easy as that? coz i already have the 20amp fuses and it looks like you just pull the old ones out and put these new ones back in
Old Dec 8, 2003 | 07:58 AM
  #53
LancerGDI's Avatar
Hey! those look like mine! Heh...
