Why is the clear coat not drying?
Old Jan 19, 2004 | 11:08 AM
pgmike's Avatar
A couple of friends and i painted my stock grille black on thursday the 15th and the clear coat is still fairly soft. I have kept it in the house the last couple of days where it is warmer and less humid. Actually it was big dan that did the painting and he applied each layer of paint too soon when each layer was not quite dry. Could this be the cause of the clear coat not drying? How long should it usually take to dry? Thanks guys.
Old Jan 19, 2004 | 11:12 AM
Iamkar33m's Avatar
Color should be applied in THIN layers and should be tacky before putting another layer on (generally 15-20 minutes in between). The clearcoat should be done in 1 layer and it takes 24 hours to dry to the touch and 72 hours to COMPLETELY cure. Use an area heater to help the curing process.
Old Jan 19, 2004 | 11:26 AM
pgmike's Avatar
the layers of paint were done evry 20 mins or so. anybdoy have any idea what is not making it dry?
Old Jan 19, 2004 | 11:32 AM
Iamkar33m's Avatar
Did you guys mix in the proper ratio of clearcoat and activator before spraying the clearcoat? (This only applies if you got a clearcoat in a can that requires activator)
Old Jan 19, 2004 | 11:47 AM
pgmike's Avatar
i dont think it required activator
TomekEVO
Nov 29, 2017 12:13 PM
Tpriem10
May 2, 2009 07:57 PM
jrhecker
Feb 26, 2006 02:55 PM
Iamkar33m
Lancer How Tos / Installations
Jul 12, 2004 09:46 PM
