New Evo Spoiler
New Evo Spoiler
I just picked up this wing
As you can tell it needed some work. The first thing i did was take a razor blade and scrape away all of the white spots and loose clear coat.
Next i wet sanded the whole top side with 800 grit sand paper. It didnt take any clear coat off but rather smoothes it all out. The whole wet sanding took about 3 hours total time. I worked bit by bit.
THe next thing i did was clean the top of the spoiler off and got it ready for painting. I went to auto zone and picked up a spray called Dulpi Color High PErformance Wheel Coating. It sprays clear and dries clear. It only cost $5.xx too. I put about 8 layers down and waited 30 min in between. This is what my new spoiler looks like. Thanks
As you can tell it needed some work. The first thing i did was take a razor blade and scrape away all of the white spots and loose clear coat.Next i wet sanded the whole top side with 800 grit sand paper. It didnt take any clear coat off but rather smoothes it all out. The whole wet sanding took about 3 hours total time. I worked bit by bit.
I didnt wet sand the spoiler in the new pics but it has been done since then. I am putting it on my car tonight. I did all the work by myself and i am only 16. I hope it looks as good as i want it to lol Thanks
nice work!, i have a similar story, check my topic it might interest you, https://www.evolutionm.net/forums/la...re-making.html
richardjh
22
Feb 11, 2019 04:20 AM
TomekEVO
Nov 29, 2017 12:13 PM
DRFTKNGG
May 31, 2016 04:46 PM
