stock grille
Old Jan 26, 2004 | 06:13 AM
Supa_Kimchee's Avatar
stock grille
ay yo, how do you get the mitsu symbol out from the stock grille?
Old Jan 26, 2004 | 06:18 AM
HobieKopek's Avatar
Pry it off with a screwdriver.
Earl Needham's Avatar
Veteran: Air ForceVeteran: Marine Corp
If yours is like mine, it's literally stamped into the metal. You'd have to hammer it out or else find an aftermarket grille that doesn't have it.
E.
Old Jan 26, 2004 | 06:19 AM
HobieKopek's Avatar
E.
The area around it is bezeled, but you could theoretically fill it with something like Bondo or plastic gap filler if you just sanded the area and repainted the surround on the grille.
BTW, it's plastic. Don't try to hammer it out or you'll be buying a new grille.
Old Jan 26, 2004 | 06:24 AM
There must be several different versions of the stock grille, as I've seen other references to removing the emblem from the stock grille. However, I just walked out to the garage to verify this -- mine is "stamped" into the grille, and it appears to be chromed plastic, not metal. Hmm...
E.
Old Jan 26, 2004 | 06:26 AM
HobieKopek's Avatar
I'm 99% certain it's the same. It's a diamond star piece of plastic attached with adhesive inside a diamond star shaped bezel. If you have a thin knife or paint scraper I guarantee you can get it off.
Old Jan 26, 2004 | 06:33 AM
aight kool thx, for all the help
Old Jan 26, 2004 | 11:42 AM
CoronaLancer's Avatar
I used a screwdriver back when I painted the whole thing...be careful though because the logo is fragile in the middle and can break in half. I have a ralliart grill now.
