replacing the side blinker bulbs (on fender)
Old Mar 3, 2004 | 11:40 AM
deuxforever13's Avatar
i tried prying it out gently with a flat head screw and ended up chipping a piece.
does anyone here know how to remove the housing properly so that i can get to the bulb?
is it held by a plastic clip that hooks on to the fender? or is it adhesive?
i can nudge it and it works, but i can't get it off.
dont wanna pull too hard cuz i'm afraid to scratch the fender and breaking the plastic housing shell.
let me know.
Old Mar 3, 2004 | 11:43 AM
jtc's Avatar
jtc
it's a plastic clip that bends and snaps in place.
it's not so much a prying motion as using the screwdriver to push the clip in so that the piece comes out. you can pry outwards with your fingers once the clip is released. make sure your screwdriver is covered in a soft cloth too.
Old Mar 3, 2004 | 11:46 AM
psionic98's Avatar
instead of a screwdriver, try using a credit card... safer on the paint and all... go in from the front bumper.. if im not mistaken thats where the clip is
Old Mar 3, 2004 | 11:52 AM
jtc's Avatar
jtc
what he said. use something non metallic, safer on the body paint too. except i go from the back. but it might work both ways.
Old Mar 3, 2004 | 11:57 AM
thanks alot guys, u guys been very helpful.
and yea, the credit card worked bets, and the plastic hook part is in the front so if we push strong enough u can pull it out.
and i dont recommend using credit card, might damaage, use like ur gas card orsomething...
thanks again.
Old Mar 3, 2004 | 12:58 PM
younggotti's Avatar
what i did was i went inside of the fender through that black thingy near the tire and just twisted off the blub....really easy
Old Mar 3, 2004 | 01:02 PM
lancerozr's Avatar
take a thin flathead screw driver and wrap it 2-3 times in a 100% cotton rag\towel -- i've removed em a few times and never had a scratch\chip! works for me.. goodluck!
- rob
EDIT: just push it straight in (from the rear) and then gently tap the handle towards the car to pry it -- it will pop right out
Old Mar 3, 2004 | 01:15 PM
jtc's Avatar
jtc
read the thread before you post. he did it already, and using a much paint-friendlier way. :P
Old Mar 3, 2004 | 01:17 PM
Stumpy221's Avatar
if im not mistaken it says how to take it out in the mitsu manual that came with the car.
Old Mar 3, 2004 | 02:01 PM
OZLancerlunatic's Avatar
i replaced my sidemarkers with some sheet metal, weld, and bondo.
Check the registry.
Old Mar 3, 2004 | 05:40 PM
modelchris's Avatar
Yo
OH my GOd, guys, it's easy. For those who haven't done it, and for those who did all these crazy stunts just to take the frickin bulb out. Its the easier bulb to replace, you just use a FLATHEAD and pry out the lens, and it comes out easily, and then, u twist the bulb out from the connector, and pull the bulb out. SUper easy, takes like 5 mins at the MOST...Why in the world would u go around the fender, through where the tire is? Or under the hood? It's totally EXTERNAL work.
<chris>
Old Mar 3, 2004 | 05:44 PM
younggotti's Avatar
how is it external work?? u gotta pull the socket out through the back
Old Mar 4, 2004 | 12:23 AM
RollerPyro's Avatar
Incorrect. I did exactly as the manual said and just popped the thing right out of my fender. I think the lens and socket came out as one. Seriously, easiest thing ever.
Old Mar 4, 2004 | 08:19 AM
modelchris's Avatar
hi
i mean, seriously, it IS in the manual! hahaha.
<chris>
