Console Lights All-In-One How-To
Old Apr 6, 2008 | 06:28 PM
  #196
Rancidx's Avatar
Here's my work in progress...
So far I have the tach and the speedo done with the EL panels...
You can see the comparison with my old style gauges using stock lighting and the blue transparent plastic
I still have to have them reprinted since the black still lets some light through.
Then I need to stick the inverter somewhere in there and either find the light+ground wire(i know it's one of the cable on the right) or solder a cable onto one of the existing light bulb sockets and plug it into the inverter...
Attached Thumbnails Console Lights All-In-One How-To-gauges1.jpg   Console Lights All-In-One How-To-gauges2.jpg
Old Jul 2, 2009 | 12:47 AM
  #197
Lumpydonut's Avatar
All the lights can be bought at
autolumination.com
GREAT write up btw, probably going to order lights this weekend
Old Jul 2, 2009 | 05:06 AM
  #198
asplodzor's Avatar
Originally Posted by jtc
All in all, I would set aside a good two hours. Make sure you have all the bulbs ready to go, because it will be painful if you have to take your dash apart multiple times like me.
All my bulbs were purchased at:
http://*************************
Climate control, ashtray, cigarette lighter bulbs (#74):
http://********************/74.htm
2 for climate control
1 for ashtray
1 for cigarette lighter
Gauge cluster and auto shifter (#194):
http://********************/194.htm
2 for gauge cluster
1 for auto shifter
Do NOT use LED's, light dispersal on LED's is horrid. Only buy normal incandescent filament bulbs with the coloured glass.
Good luck.
Links got completely screwed up. Is this some type of old forum rule or something?
Old Aug 21, 2009 | 12:37 PM
  #199
yukyucky's Avatar
what size are the twist lock bulbs for the lancer es cluster
is it 5mm or 3mm
Old Jun 4, 2011 | 05:30 PM
  #200
Jimbowned's Avatar
hey guys i ran into 2 very serious problems changing the lights in my HVAC. Apparently, 2006 has a different bulb size for the HVAC controls than the other years, which is my first question, what is the size number of these bulbs? This is where my problem got bad. I tried to pull these bulbs out not knowing they were incorrect and it was a 2-pronged thin wire that plugged in, and when i (stupidly) slightly twisted the bulb and the prongs snapped off inside the adapter. Does anybody know where i could find a replacement female plug for these/ know the actual name so i can get from my dealership. Also, if anyone would know how i would go about replacing this it would be greatly appreciated. thank you guys for all your help.
Old Jul 11, 2011 | 06:01 PM
  #201
creat1on's Avatar
Great write up.
Old Jul 12, 2011 | 01:18 PM
  #202
eGadz's Avatar
Great tutorial many thanks to you!
Old Jul 28, 2011 | 01:19 PM
  #203
Jimbolion's Avatar
good job!!
Old Aug 1, 2011 | 03:14 PM
  #204
Avirex's Avatar
Great How to
This How to was awesome! Looks like i'll have to do this to the ES gauges I now have in my OZ lancer. For some reason when i had it changed from a automatic to a manual the dealership changed the gauge cluster. So no my cluster doesn't match the gauges i have mounted on the pillar, awesome....
Old Aug 15, 2011 | 07:16 PM
  #205
Avirex's Avatar
THANKS SO MUCH TO Z_LANCER MAN!
I LOOOOOVE my new lights!!
Old Aug 15, 2011 | 10:28 PM
  #206
OZR_Lancer's Avatar
nice on gettin it fixed ...
Old Aug 16, 2011 | 04:37 AM
  #207
Avirex's Avatar
Ha, only reason i got it fixed is because of you. Thanks again so much man for helping me get my cluster fixed. I only have 1 problem now, i keep staring at them.
Old Aug 29, 2011 | 11:19 PM
  #208
Z_Lancer_Man's Avatar
Looks great! Now you just need to convert your stock radio to red as well!
Old Dec 31, 2011 | 06:48 PM
  #209
Resurrected RA's Avatar
Switched the old LEDs the original owner had installed.
I can finally see what I'm selecting.
Old Jan 27, 2012 | 12:10 PM
  #210
Tapsta's Avatar
wow. very nice write up!
