Aftermarket pedals
Old Jun 24, 2004 | 01:55 PM
ambystom01's Avatar
Aftermarket pedals
Are there any aftermarket pedals that require the removal of the stock ones? If so how do you remove the stock ones and install the new ones?
Old Jun 24, 2004 | 02:03 PM
MY2003OZ's Avatar
Registered User
do you mean the whole pedal setup or the rubber that is attached to the metal??
Old Jun 24, 2004 | 02:04 PM
ambystom01's Avatar
just the rubber stuff i guess
Old Jun 24, 2004 | 02:07 PM
MY2003OZ's Avatar
Registered User
yeah, my momo pedals required that. It makes the pedals feel like they are stock height and not as bulky as some cheaper ones. Plus they make it a little easier to shift (at least for me).
Old Jun 24, 2004 | 02:09 PM
ambystom01's Avatar
Where'd you get your momo pedals?
Old Jun 24, 2004 | 02:12 PM
ambystom01's Avatar
and how'd you remove the stock rubber?
Old Jun 24, 2004 | 02:15 PM
rpm-evo's Avatar
What are your momo's made of? I'm also interested in replacing the nasty rubber stock pedals, and like the carbon fiber sparco's but was not sure if they might break and that a metal based pedal would be better.
Old Jun 24, 2004 | 02:57 PM
ambystom01's Avatar
bump
Old Jun 24, 2004 | 05:07 PM
ambystom01's Avatar
bump
Old Jun 24, 2004 | 05:15 PM
mcbrown35's Avatar
Grab a corner and pull...
It is a ***** to install pedals if you have to drill. (Some cheap kinds have clamps that slide on and adjust with bolts and nuts and brackets) The stock pedals are very thick and you have to deal with the very thick bar that the flat part of the pedal is attached too. the gas pedal is even worse as it is a plastic piece molded around the metal. Mine are crooked but I haven't bothered grinding them and straightening them. (look in my registry for a pic...) i have Sparcos.. they are metal. Will get new ones but not a high priority. Need a clutch.
Old Jun 24, 2004 | 05:16 PM
cautiontext's Avatar
I had to drill mine for the screws. It went pretty sweet, but I had to remove the lower part of the dash and the support bar to get the drill at a 90 degree angle. Pretty easy install...check my profile to see my pedals
Old Jun 24, 2004 | 05:20 PM
mcbrown35's Avatar
OK maybe I'm retarded and made it more difficult than it was...
Old Jun 24, 2004 | 05:30 PM
ill trade u my straight pedals for your Stage 2 lol...
Old Jun 24, 2004 | 06:33 PM
poorguynamedbob's Avatar
mitsu... has some factory pedals that are pretty sweet looking.... they come in blue or silver aluminum
Old Jun 24, 2004 | 07:51 PM
freakoz's Avatar
i got momo and i didnt remove the rubber. sticks better with the rubber on.
