Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Autocrossers: give me your advice
Old May 24, 2005 | 05:30 PM
bobaab's Avatar
thanks for your info man, that was a great bit of information there!
Old May 24, 2005 | 09:22 PM
03RallyLancer's Avatar
Originally Posted by jason33hs
R-compounds are your next step-2+ seconds on a 45 second course on my car.
word local stock car (when he shows up) kicks my *** by about that much with those r-compounds
Old May 24, 2005 | 11:51 PM
Alchemist's Avatar
bob- I have 4 stock dampers with about 25K miles on them just looking for a good home. PM me.
WorstPlaya: thanks for playin' but there is NO front camber adjust on the lancer. You're thinking you're in Evo tech No caster adjust either. toes are adjustable and this is where you'll get the most gain and the most wear. Premature wear across the tire is a result of bad toe. extreme camber can cause the toes to go all wonky, because as we all know all the different systems are linked together.
The camber bolts- if you use 2 per side, will yield about -1.75 deg camber and won't have a bad effect on toe.
and after all that, don't expect much difference in your times. You need autocross school. Chances are you're turning too late in your slaloms to make the next cone, hitting the brakes too hard and giving it too much gas out of the corners. a full 8 hour day of running short slaloms (get smaller as you go through), fast/long slaloms, 180deg turn practice and a practice autocross course will do more than any car mod.
Repeat the phrase "seat time" until you pass out
Good luck
ninjacoco
Aug 13, 2014 08:45 AM
hispanicpanic
10
Mar 1, 2014 04:07 PM
19psi
13
Oct 8, 2006 09:08 PM
Go_Lancer_Go
32
Feb 18, 2006 10:51 AM
quikkstylez
Nov 15, 2005 11:33 PM
