Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Extended Studs
Old Mar 28, 2006 | 08:31 AM
Jokiesmurf's Avatar
Extended Studs
Where can I find some extended studs?
Did a search the only thing I came up with is a compamy name RRE. Don't know the correct name for me to go & check it out.
I put in .25 inch spacers due to my tires rubbing a little, but now I don't have a lot of thread left. So I want to put in longer stud it better than buying 4 new tires all over again. I went to local speed shop they told me to buy 52mm & cut then. but PEPBOYS nor the speedshop carry then. Any help of what size I think stock is 12 X 1.5. So what size extended stud should I get & where to find then at.
Old Mar 28, 2006 | 09:09 AM
gregivq's Avatar
www.summitracing.com
Any pics of your setup before and after?
Old Mar 28, 2006 | 10:17 AM
Jokiesmurf's Avatar
No pic I used to have 205/40/17 on. But to many pot holes here in Philly I bend 2 of my Sacchi s8 rims. this pic. was with my 205/40 I got them fix. got bigger tires 215/45/17
Old Mar 29, 2006 | 01:18 PM
Blacksheepdj's Avatar
RRE? That'd probably be Road Race Engineering, if you found it on EvoM.
http://roadraceengineering.com/default.htm
Old Mar 29, 2006 | 07:38 PM
Jokiesmurf's Avatar
thank you. So far the ones I have found are Skunk 2 & ARP.
Old Mar 29, 2006 | 09:00 PM
gregivq's Avatar
Try looking for wheel spacers with studs, wheel spacer kits.
Sly Moose
11
May 27, 2011 06:33 AM
06redrocket
10
Mar 8, 2011 06:45 PM
EGHBauce
Northwest Region
Apr 20, 2010 08:52 PM
Aux.
Oct 31, 2005 07:29 PM
PinnacleChronos
Jun 6, 2004 04:17 PM
