Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
strut bar
Old Jul 23, 2007 | 10:39 AM
shinbumee's Avatar
strut bar
hi, i have a question about how to install strut bar?
i tried to take off the front nuts under the hood but it just won't come off.
the car was sitting down. or do i have to raise the car up?
Old Jul 23, 2007 | 10:43 AM
crypto's Avatar
Former Vendor
the car can be sitting down, it doesn't matter. But if you haven't removed those nuts before they will be very tight. Try buying some PB Blaster to loosen them up
Old Jul 23, 2007 | 10:45 AM
shinbumee's Avatar
yeah, it's crazy tight,
okay, i'll try that. but on the strut bar, there is the adjusting bolt.
it can be shortened or longer, do i have to set that tight? or regular?
Old Jul 23, 2007 | 10:48 AM
crypto's Avatar
Former Vendor
you probably have an ebay bar right?
i would assume you do it tight. I have an adjustable lower tie bar and i got it pretty tight.
Old Jul 23, 2007 | 10:58 AM
shinbumee's Avatar
okay, thanks
Old Jul 23, 2007 | 12:11 PM
*Zero*'s Avatar
keep it tight for better cornering post pic when done
Old Jul 23, 2007 | 12:16 PM
SLVROZ_03's Avatar
Sounds like you've got all the info you need...good luck prying those suckers off! At least their not lower front strut bolts (19mm I think); now those took a pipe and a half!
Old Jul 23, 2007 | 12:25 PM
shinbumee's Avatar
it'll take a while to post pics.. i'm pretty busy nowadays
but i'll try to do it fast as possible!
Old Jul 25, 2007 | 06:41 PM
shinbumee's Avatar
hey guys, i'm gonna install the front strut bar tomorrow.
quick question about strut bars.
if i install the front, do i have to install the rear too? just curious
Old Jul 25, 2007 | 06:46 PM
ambystom01's Avatar
No, they are independent of each other.
Old Jul 27, 2007 | 07:05 AM
shinbumee's Avatar
tried that pb blaster. won't come off
Old Jul 27, 2007 | 07:34 AM
blaze_125's Avatar
some elbow grease or an impact will get it off
And don't forget. Righty thighty, lefty loosy
And put an extension on your wrench if you're having a hard time.
enthuziast
Lancer Engine Tech
Jul 11, 2016 04:45 PM
nickleo373
Jan 27, 2015 11:54 AM
TopLevelPerformance
Jul 5, 2014 01:18 PM
ozmaster
16
Mar 14, 2005 08:38 PM
Rawdog5581
15
Dec 19, 2003 06:30 PM
