Stock EVO X wheels
well…
so i would assume that a 245/40/18 tire on an 18x8.5 rim would cause some problems…
right?
Official wheel/tire info thread:
General info
A 245/45/18 size tire will not fit, as confirmed by CrEsT (tested on 18x8 wheel).
General info
right?
Forgot to check back, but the issue is offset. Same as with past Evos, they have the widebody plus are clearing the brembos. Their lower offset means rubbing for you guys. If I've read correctly, Evo Xs have +38 wheels and you have +46. Not the most massive difference, but can be enough to cause bad rubbing issues. Same reason why the Ralliart guys can't run Evo VIII/IX wheels.
GUYS, EVO X TIRES ARE NOT 245/45/18, THEY ARE 245/40/18. I'd be hardpressed to believe they rub on a base model lancer. Yea there is an 8mm difference in offset but the lower sidewall should counteract that.
overall diameter of 245/45/18 is 26.68" (this will not fit due to the larger difference)
overall diameter of 245/40/18 is 25.71" (this is stock evo)
overall diameter of 215/45/18 is 25.61" (this is stock lancer)
it will be a tad bigger, as above, but should fit, the offset is what you want to think about. When you turn your wheels lock to lock you dont want rubbing.
