Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
front hubs
Old May 24, 2008 | 01:38 PM
ev0_nada's Avatar
front hubs
hi i need to take off the hubs on my oz, could you explain the procedure w/ torque specs.
Also looking for rear sway bar and front struts w/ lowering springs
thanks!!!
Old May 24, 2008 | 06:35 PM
senate6268's Avatar
Remove strut bolts, disconnect tie rod end, disconnect lower ball joint. Then with the knuckle off, remove the snap ring from the back and press the hub out from the back. Be sure and replace the bearing when re-installing.
Old May 26, 2008 | 06:09 PM
mcgarvey's Avatar
That would remove the KNUCKLES.
Old Jun 4, 2008 | 08:52 PM
ev0_nada's Avatar
any one know the tq on the hub nut?
any one have front struts w/ lowering srpings?
thanks for the info guys
EvoTeyn
May 27, 2011 08:12 PM
Evo D
Jul 13, 2010 04:32 PM
AngryEvo8
14
Jun 29, 2009 11:51 PM
Mitchubishievo
15
Oct 15, 2008 11:02 AM
cmz
Oct 30, 2007 09:35 PM
