Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
rim
Old Aug 17, 2003 | 08:24 PM
alive307's Avatar
jacked my rim's up
i have a cracked rim anybody know any were in houston who can fix it, how good is the rim after its been fixed .......should i just buy a new one.......................the pot holes here are freaking mean ......i have one rim that is cracked on the front driver side and the other front rim is bent damn these low profile tires
Old Aug 17, 2003 | 09:42 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I don't think they can repair a cracked rim, but a bent rim can be straightened pretty well. It won't be quite as strong as before, though. What profile tires are you running? You might want to start running at least 35 psi to be safe, and check it all the time.
Old Aug 18, 2003 | 06:50 AM
Neal@tirerack's Avatar
The structural integrity of a wheel is always compromised when it is repaired. The repaired section of the wheel becomes the weakest part because the metal has been worked. Also, you have to make sure the wheel isn't out of round once the repair has been made. We usually recommend against it.
Old Aug 18, 2003 | 10:10 AM
alive307's Avatar
the crack is on the inside wall of the rim not visuable at all found it with water very small bearly leaks at all so i hope it well not be that week after repair
Old Aug 18, 2003 | 01:50 PM
alive307's Avatar
wel it cost just as much to get it fixed as it does to buy a new one so im buying a new one.......wish it would not of happend though takes money away from other mods i was wanting
Old Aug 18, 2003 | 11:32 PM
Moderator
Bomb Squad Unit #02
ahh the joys of owning a car. To maintain, or to mod. That is the question.
Dr3zA
May 18, 2016 12:56 PM
nawgee
Nov 19, 2008 08:30 PM
eVosmAs2006ix
Northeast Region
Jul 5, 2007 12:48 PM
LoCo4
Midwest Region
Dec 20, 2005 09:59 PM
purecoda
May 5, 2003 07:49 PM
