Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
rrm spring install ?
Old Jul 20, 2008 | 06:16 AM
kanyonkid's Avatar
i installed the rrm springs on my girls lancer, and the springs clunk a lil up front when hittin a bump and goin up my driveway, do they need to break in? or should i remove and rotate the top of the strut? thanx
P.S. the spring is sittin on the bottom in its correct spot. not sure if the top is and not sure if the top matters..
Old Jul 22, 2008 | 09:49 AM
kanyonkid's Avatar
no luv?
Old Jul 24, 2008 | 08:48 AM
FastGTS's Avatar
help this guy out.......when u first installed them they have to settle down to its appropritae height.
Old Jul 29, 2008 | 05:43 PM
Elvis077's Avatar
Yeah, I had the same thing going on for a few days (or weeks cant remember) but they settle in. Just be sure to check all the nuts and bolts again to be sure they remain tight. Then get alignment.
Old Jul 30, 2008 | 02:04 PM
nunyas's Avatar
I installed my RRM v2 springs myself. They never clunk and I go through some pretty steep driveways and parking lot entrances and my suspension never clunks. I'm talking about driveways and parking lot ramps so steep that I loose traction on the front because the front inside wheel is barely touching the ground.
Make sure you have the spring seated in the perches properly (bottom AND top). Also make sure you have the top spring perch mounted properly in the strut tower with all the washers, grommets, and spacers. Make sure they're centered, fully seated, and make sure there is NO slack.
Old Aug 24, 2008 | 10:13 AM
08Lancer89's Avatar
can someone post a how to install RRM Springs
Old Aug 25, 2008 | 12:40 PM
nj_08_gts's Avatar
There's a How-To for the WORKS branded springs. The same steps can be applied to the RRM version.
Chops
09+ Ralliart Show and Shine
40
May 15, 2010 06:48 AM
nmilsaps
Apr 21, 2010 01:56 PM
mb09ralliart
Oct 5, 2009 09:02 AM
Piper747
42
Aug 16, 2009 09:45 PM
gatzaraki
37
Sep 17, 2007 10:48 PM
