lowest offset
lowest offset
okay so everyones pretty much saying 17x7.5 wid +42 offsets the max..
but whats the lowest offset we can run?
cuz im gonna pick up some 15x8 rims wid 0 offset.. so lmk you guys whats the lowest we can run?
That's way too low of an offset, if you drove a 240SX or an AE86 it'd be fine but considering stock is +40ish, going to +10 will cause a butt load of problems. First off, I doubt the wheel would even fit. If it did, the tires would almost certainly rub. Then you'd have camber issues and the previously mentioned strain on the bearings.
saw this thread and wanted to put my 2cents in . i just had to swap wheels cause i curbed both passengers
well i have a set of falkens off my rx7 with a +32 offset 17x7.5 with a 215/45/17 tires and with the 2inch or so drop i rub hardcore on the outer fender . the wheels set completely flush with the fenders front and back looks great just got to roll my fenders a lil bit and its gravy
well i have a set of falkens off my rx7 with a +32 offset 17x7.5 with a 215/45/17 tires and with the 2inch or so drop i rub hardcore on the outer fender . the wheels set completely flush with the fenders front and back looks great just got to roll my fenders a lil bit and its gravy saw this thread and wanted to put my 2cents in . i just had to swap wheels cause i curbed both passengers
well i have a set of falkens off my rx7 with a +32 offset 17x7.5 with a 215/45/17 tires and with the 2inch or so drop i rub hardcore on the outer fender . the wheels set completely flush with the fenders front and back looks great just got to roll my fenders a lil bit and its gravy Btw, what year 7 do you have?
What offset and wheels would you suggest when I do my evo brake swap. I know I have to have at highest a +38 offset to clear the brake calipers and smallest rim would be 17x7 or 17x7.5. I would like 17x7.5 but I don't know the best sized tires I want to go with. I was hoping to get somewhere around 225x45 or 50, r17 tires. Would they fit on an OZ since it is slightly lowered? I'm trying to prevent rolling the fenders.
