Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Question before I lower it
Old Jul 6, 2009 | 10:59 AM
stanrc's Avatar
I've had my 09 Lancer GTS for over a year now and have been itching to lower it since the day I got it. My previous vehicle was a lowered Chevy Xtreme and I loved it being low but it was a real pain. The truck was too low to drive on lifts or fit jacks under and it was a huge hassle just to change the oil. not to mention rubbing issues. So before I commit to lowering my Lancer i want to know from others if anyone has experienced this. I only want to lower about an inch or so all around (most likely with RRM Grip springs, but I'm open to suggestions).
Old Jul 6, 2009 | 11:08 AM
evoooo's Avatar
i had this problem before with my 06 scion tc...i had Progress springs and full kaminari body kit and i couldnt get on any lifts without taking my side skirts off...it was a pain but well worth it...my evo X is lowered on eibach with the SSS aero kit and its real low Im going in for an alignment this week and will see how it does on a rack...you should go with tein springs for the lancer...you should'nt have any problems b/c that car sits up high stock anyways...good luck and post pics!!!
Old Jul 6, 2009 | 11:46 AM
EngRWW33's Avatar
Works - 1.1" all around
Teins will lower too much and handling will get worse. More then 1.5" is way too much. I have heard good thing about the Grips spring as well but cannot personally vouch for them.
Old Jul 6, 2009 | 11:52 AM
stanrc's Avatar
Thanks, I'll look into WORKS too.
Old Jul 6, 2009 | 01:22 PM
Greedy_son's Avatar
Lowered on Eibach sportlines and have had an alignment and multiple oil changes done so far and no problems. Sportline = 1.7" F and 1.5" R
Old Jul 6, 2009 | 02:31 PM
funkad3llic's Avatar
i just installed my teins and its awesome
Old Jul 9, 2009 | 11:59 PM
djslik408's Avatar
The Eibach Sportline is also good. 1.7 F and 1.5 for the Rear. My buddy just dropped his with the Eibachs two weeks ago and so far so good. Im also leaning that way and it sure is a lot cheaper for $173 for the whole set!
Old Jul 12, 2009 | 04:37 PM
SirLancerlotWPG's Avatar
Just finished putting in the Eibach Sportlines, and will give an update of the differences, and also will get an alignment done probably tomorrow or sometime this week. Just have to say though, it's not all that hard of a job, but removing those bolts from the sway bars were the biggest problem, and also ligning the bolts up once completing the job.
Old Jul 12, 2009 | 05:21 PM
EVO8904's Avatar
How is the install for the rear springs? I installed coilovers on my EVO and the rears were a PITA.
Old Jul 12, 2009 | 07:10 PM
JHizzle's Avatar
dont go with the RRM ones..go with Tein or eibach..possibly works..depending on how low you wanna go.
Old Jul 13, 2009 | 05:26 AM
Ya, they were a bit of a pain, took a bit of swearing to get it back together!
Old Jul 13, 2009 | 05:13 PM
Here's a couple pics with the Sportlines installed:
Old Jul 13, 2009 | 06:19 PM
seanymack's Avatar
very nice, how big are those rims?
Old Jul 13, 2009 | 08:33 PM
18's, used the stock rubber.
Old Aug 3, 2009 | 09:39 AM
FLOW1's Avatar
tein are awesome
