Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
camber kit ????????
Old Sep 2, 2009 | 01:27 PM
negrito 18's Avatar
camber kit ????????
i just installed my lowering springs yesterday n got ma car aligned 2day n they told me tha cause off my lowering springs they couldnt adjust my camber :/ so now i really have 2 buy a kit 4 it so i really need help in where i could buy it thanxs guys
Old Sep 2, 2009 | 01:30 PM
scumrat's Avatar
not enough question marks in your title so i cant help you out.
Old Sep 2, 2009 | 01:34 PM
Neal@tirerack's Avatar
We carry the Ingalls 14mm cam bolts for the front end. One bolt will give +/- 2 deg of camber, the other +/- 1 deg of camber. Both options are in stock.
Old Sep 2, 2009 | 01:48 PM
ThunderOZ's Avatar
Not to bump out Neal@tirerack since he is a great guy, but I got my set(2) off of ebay for about $20...
Old Sep 2, 2009 | 02:07 PM
user 620842029's Avatar
Isn't that almost the same price as TireRack?
One thing I've discovered is that there are shops who don't know how to adjust camber on our cars. Why, I'm not sure, but I've run into that.. They can't seem to see the camber adjustment on the front end. Story I got was that ALL fwd cars have solid front ends - which obviously isn't true!
Old Sep 2, 2009 | 02:14 PM
ThunderOZ's Avatar
It's pretty close. The Ingalls I purchased could go up to -2 - +2 and was $20 for both, not $20 each(making it $40)
Old Sep 2, 2009 | 02:31 PM
negrito 18's Avatar
cause my rear caster both are sitting right now is -2.0
Old Sep 2, 2009 | 02:58 PM
negrito 18's Avatar
my cars rear tires are leaning towards tha inside of tha car like in an angle n they told me tha in a couple of months if dont fix it tha i will have to buy new tires cause tha inside will get worn faster
Old Sep 2, 2009 | 03:17 PM
ThunderOZ's Avatar
Well the camber kit is for the front... The rear is pretty adjustable... I had mine set back to 0 and it was almost to the tire...
Old Sep 2, 2009 | 06:55 PM
Oh ok, my bad.
Old Sep 2, 2009 | 09:54 PM
4g94T's Avatar
go to a different place. They don't know what they're talking about
Old Sep 3, 2009 | 07:37 AM
negrito 18's Avatar
Well if I try 2 adjust my rear camber tha max tha it will reach is -1.2 degrees but if I do leave it there tha toe will b all messed up so I told them 2 leave tha camber -2.0 so tha toe is bak at zero so idk wat 2 do n wat 2 buy so tha rear camber goes bak 2 zero n my front is fine
Old Jun 10, 2010 | 06:25 PM
ace99x2002's Avatar
my alignment
the guy who did my rear alignment used a F**King impact wrench and mushroomed mine and told me it was my fault . yea ok . but i found some on Rock Auto but I dont Know if thats the right one i need any ideas
o my rear alignment sits out about -1.5
Old Jun 11, 2010 | 05:08 PM
slatermvp's Avatar
Anybody know where I can get the rear?
Old Jun 15, 2010 | 04:39 PM
Unless something in the back end is damaged, the stock camber bolt has enough movement in it to properly setup the rear camber, even if your car is seriously low. I haven't seen a rear camber kit for our cars, and that's probably the reason why.
I've had my car low enough that the rear tires were tucking, and we could easily center it to sit within spec.
