Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Lancer 08 - offset question
Old Sep 11, 2009 | 02:22 AM
Miha's Avatar
I wonder if anyone knows will be rubbing if I mount following rim:
- 18 * 7.5 offset 35
I have time until Monday, when the contract may be changed for the ET42.
tx
Old Sep 11, 2009 | 04:30 AM
EngRWW33's Avatar
that's a good question. I know that with a wider wheel you would be rubbing a bit in the rear (sounds dirty... lol), but with a 7.5" wide wheel it might be different at stock height. Either way, you would be better off with rolling the rears or going with a higher offset then +35.
Old Sep 11, 2009 | 05:37 AM
Miha's Avatar
tx
but with et35 will look good
Old Sep 12, 2009 | 10:23 AM
cRc`22's Avatar
at stock height running 18x8+35 235/40 i only rubbed in the rear passenger side as long as u run a smaller tire since ur only gonna have a 7.5 inch wide rim u should be fine even if lowered..
Old Sep 14, 2009 | 12:30 AM
Miha's Avatar
It's lowered -3,5 with H&R
Old Sep 14, 2009 | 07:44 AM
JHizzle's Avatar
yeah same here..i get the occasional rub on the rear passenger..and it rubs if i have people in the back seat harder..gonna get it fixed soon..so with 7.5 rims you should be fine
Old Sep 14, 2009 | 08:40 AM
Miha's Avatar
I take now ET42. I ordered wheels from the UK, so that they then can not return. Would be large costs.
Old Sep 16, 2009 | 02:48 PM
jungene's Avatar
I have 18x7.5 w/ et:42, I am running 225/45/18 and my car is also lowered by h&r, I have no problem or rubbing. I hope this helps. I think it should be good but can't tell, I can check it if you want to bring your car to the shop I own a car accessories, rims and tires. Im not sure where you from? thanks,
Old Sep 22, 2009 | 02:31 AM
Miha's Avatar
I'm from Slovenia (Europe). I ordered now 18''*7,5 with tires 225/40/18
evo854880
Feb 23, 2012 06:26 PM
thatguy5
Nov 1, 2011 08:18 PM
Lightsped
Feb 24, 2011 01:52 PM
BlueEvoG
Northwest Region
Apr 9, 2010 08:41 PM
Clarkie1685
14
Apr 6, 2010 03:24 AM
