Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Car still pulls left after allignment??
Old Sep 30, 2009 | 05:46 AM
RTW EVO's Avatar
Looking for a little assistance... I lowered my car a few weeks ago. I waited a week for the springs to settle and proceeded to get an alignment at Firestone.. Everything checked out, I saw the spec sheet and all the wheels were within spec after they were done...
My question is; the car is still pulling to the left (same as it did when it was stock), is this normal? Is this car destined to pull left all of the time? Or did I just get a crappy allignment?
Old Oct 1, 2009 | 04:21 AM
kalpakiotis's Avatar
are your tires worn abnormally? i lowered mine about 2 months ago and its still running straight as an arrow.
Old Oct 1, 2009 | 04:35 AM
4WS Tuning's Avatar
Its normal for a car to pull "slighty" to the right because of how most roads are paved to push water off the road to the shoulder... To the left you have something going on.. Take the car back to the place you had it aligned and let them drive it.... If its not the alignment they'll figure it out for you.
Cheers!
Old Oct 1, 2009 | 04:37 AM
xspsi4's Avatar
Yes check your tires for wear and if that checks out I would have them do it again as many alignment shops will just "bump" the sensors to get the proper reading, I would not get an alignment unless I can watch every step of the way.
Old Oct 1, 2009 | 04:57 AM
trboboost91's Avatar
compare apples to apples.
drive down the highway in the same lane same streach. pay attention to what the car does IE pull left/right slightly/hard or not at all.
jack car up and swap front tires/wheels left to right (i don't care it they are directional this is just to diagnose your problem.)
re-test drive SAME streach of highway SAME lane.
whats it do now.
you might have whats called a "bad" tire.
it might look like its wearing fine but may have too much conicity in one of the sidewalls which affects lateral forces.
Old Oct 1, 2009 | 07:12 AM
lancer0220's Avatar
how many miles does your car have ? if its over 10k you may be pulling beacuse thats how your tires were wearing from the factory.
Old Oct 1, 2009 | 11:24 AM
RTW EVO's Avatar
I only have 3200 miles so I doubt it's a due to tire ware. Ill try swapping the front tires and see what it does, although I doubt that could be it... I'm guessing it was just a crappy alignment. Guess I'm off to firestone again to get another one. Very glad I bought the lifetime guarantee from them...
Old Oct 7, 2009 | 10:30 AM
ShadowES's Avatar
are you driving on the left or right lane(fast or slow) a perfectly aligned car will pull slightly to the left on the fast lane and to the right on the slow lane because of the way the road is designed.
Old Oct 7, 2009 | 04:13 PM
08GTSLancerBlue's Avatar
pressure
Believe it or not also check your tire pressure. I would of imagined they checked it at alignment. But you never know lots of shops like to get the car in and out. I agree it could be poorly worn tires as well.
Old Oct 9, 2009 | 04:11 PM
krnkimchi702's Avatar
i just went to firestone to get my car re-aligned because it was pulling to the left.. they said that they can only adjust my toe because the camber is not adjustable... i called the local mitsubishi dealership to confirm that the camber is not adjustable and they said it is not adjustable.. im ordering the adjustable camber kit as i type this..
Old Oct 9, 2009 | 04:20 PM
cRc`22's Avatar
AMS is possibly going to be making a adjustable control arm for the rears if u want to wait.
Old Oct 9, 2009 | 07:06 PM
my rears are fine.. its the front... i've already had to replace my tires...
Old Oct 9, 2009 | 07:08 PM
ingalls are much cheaper than rrm's camber bolts
Old Oct 11, 2009 | 12:39 PM
cRc`22's Avatar
much cheaper? u mean like 75% cheaper.. lol
Old Oct 11, 2009 | 12:53 PM
hahaha yeah... im starting to think RRM is ridiculously expensive..
