Lancer oz rear disc conversion
Just a little update on the abs kicking in at the track...the hawk hp+ definitely helped alot because the abs were activating a lot less than with the stock wilwood pads. So if you do this rear disc conversion make sure your rear pads are not too aggressive compared to the front if you're planning on doing lapping and/or autocross or your abs will kick in almost everytime you stop before a corner.
Do you know if everything between the ralliart and the sportback is the same? Is the only difference the hub assembly and the rotors?
I was reading thru a couple of threads and senate had all the Mitsubishi parts listings for a 5 lug swap. Just wondering if I could use his part numbers for backing plates and such and just get the hub bearing kit for the sportback off Rockauto.
man, sourcing an ls sportback is tough! im wondering how you got the brake calipers to bolt on. you didnt cover that in your thread. what did you pull to make that work? im really interested in the thread and found a great website for parts.
here is the link:
http://www.oemautopartsandaccessorie...c9c9b1e02990c/
here is the link:
I tried ordering thru mitsubishipartswarehouse.com and they quit making the backing plate on one side. The caliper will bolt to the backing plate.
https://www.evolutionm.net/forums/la...part-list.html
What I was getting at is the 4 lug and the 5 lug use the same parts. The only difference is that the 5 lug would use a different rear hub. So you can use that to source all the lines and hardware you want to buy new. Then instead of getting ralliart rotors you would purchase sportback rotors since they are 4x114.3, the backing plates you could use either ralliart or the sportback.
If you have abs the ralliart has the hole in the backplate and the sportback doesn't but you can always drill a hole for the abs sensor in the sportback backplate like i did.
yea, gonna just do the back. i dont know if the brake calipers would work for the front if i did the 5 lug conversion. plus i'd need a new set of wheels and shoes. i also dont have abs, and i highly doubt the ralliart came without.
