Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Tein s-tech question
Old May 31, 2004 | 09:00 PM
rebel89_00's Avatar
I was thinking of buying the s-tech's for my car. I was wonder if i need a camber kit for the front to align the car because with the springs it would lower the car 1.8" in the front and 1.1" in the rear?
Old May 31, 2004 | 09:04 PM
ghostrider's Avatar
It's been said that the rears of the Lancer can adjust for camber a lot better than the fronts can, so if anything just get a front camber kit. I've seen three cars dropped on S-Techs and none of them looked like they needed camber adjustment after several months - looking at the tread wear when swapping out tires.
Old May 31, 2004 | 09:07 PM
rebel89_00's Avatar
I've heard that dropping your car more than 1.5" will require the kit
Old May 31, 2004 | 09:24 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
You should be fine. There is no camber kit for the rear since it's adjustable from stock, and if you want to be safe get a front camber kit. Most likely, the drop will actually give you the right amount of camber up front anyway. I got -.5 front, -1 rear just from the drop.
duranvw
Jul 15, 2016 08:26 AM
Duffman19
Toronto Lancer Club
15
Apr 13, 2012 12:40 PM
Erockin
For Sale - Wheels / Tires / Suspension / Brakes
20
Jan 22, 2012 04:26 PM
pips
22
Oct 15, 2011 10:09 AM
The hundreds.
17
Aug 19, 2008 02:52 AM
