Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
help me
Old Sep 30, 2002 | 10:34 AM
CTS 1273's Avatar
help me
i whant to lower my car as low as posebel how can i do this i know that ground control makes a coilover kit to lower the car 0-3 in
Old Sep 30, 2002 | 10:48 AM
perfdrug's Avatar
3 inches is a ton. you want 12" wheels with low profile tires on it so your car will go that much lower? scrape the bottom on stones low? 3 inches is a long way to drop your car. i'd go with those
woah. we've got over 5k members now. rock on us.
Old Sep 30, 2002 | 12:21 PM
Sonantoni's Avatar
ground control is probably the best(cheapest) way to go for right now. The lower you go, the more you will sacrifice the comfortability of the ride. I advise not going too low for you will blow your stock struts
Old Nov 12, 2002 | 02:10 PM
AllShowES13's Avatar
CUT THEM! or take the springs out to totally slam it. i cut mine and lowered it 4 1/2"!! looks great, but really bumpy! not too hard but you need to know a tille about springs to decide how low you want it.!!pm me for details.
Old Nov 12, 2002 | 02:16 PM
HobieKopek's Avatar
I hope that's a joke. You know your shocks are going to pop like balloons at a porcupine's birthday party, right? Cutting springs is the worst possible way to lower you car (next to the other option you posed: removing them altogether). Do it right, buy springs or coilovers if you want to retain any semblance of a ride and keep your shocks working properly.
Old Nov 23, 2002 | 10:03 PM
shaggy's Avatar
try this
mode 99 mirage front struts with coil over kit from ground control you will need to weld cut drill and a little griding this gets you realy low plus you get some travel do not use the 99 mirage rears they are way wrong I bury 15 rims with 195 50 to the wheel arch and the lower cross meber that suports the trans and rear motor mount is about 2 inches off the ground O you will have to remove the finder well splash gaurds they rub
Old Nov 23, 2002 | 10:11 PM
ROCK's Avatar
Anything more than 2 inches and you will KILL your shocks. Don't do 3 inches. There are a lot of options for lowering a Lancer. We have a variety of suspension choices. Check out the site.
ROAD/RACE
http://www.roadracemotorsports.com/
Old Nov 23, 2002 | 10:37 PM
shaggy's Avatar
he is right
any more the 2 on the stock srut and kiss them good buy you have to have a shorter shock like the99 mirage its over an 1 3/4 shorter than the stock strut plus if you get the AGX from KYB they are adjustable and do not use the rears I am still on the hunt for a good rear
Old Nov 23, 2002 | 11:00 PM
majin's Avatar
My progress springs worked out sweet for me. The lowest i can go without killing my shocks.
Old Nov 23, 2002 | 11:19 PM
shaggy's Avatar
check out
to seehow low my car is go to omega 13 .com and go to the event section and check out coverage for the north sacrament meet mine is the silver lancer I hope this info gets you their its in their some where
Old Nov 24, 2002 | 08:47 AM
StreetLancer's Avatar
The ES should be able to utilize the front/rear struts and springs from the Mirage, whereas the OZ/LS will not be able to use the front struts/springs, although the rear ones should work...
vhalin
14
Apr 12, 2011 11:45 AM
Ralli_85
18
Jan 23, 2010 07:32 AM
evolucion
14
May 20, 2008 11:46 AM
mirage 4g93t
Apr 7, 2008 07:33 AM
Emperor 4g63
Oct 1, 2007 02:28 PM
