Will my wheels rub if i get them 17x7.5?
Will my wheels rub if i get them 18's?
I plan on doing a Progress spring drop...
I've heard of rims rubbing with 17x7.5 even without a drop
i got 18's with 215/35/zr18 tires, dropped 1.5 inches with the progress springs and they do not rub. . .
we have 17's and we get no rub. no drop yet but i am guessing we wont have a rubbing problem with the drop either.
Bomb Squad Unit #02
17x7.5 and 17x7 won't make any different as long as the offset is the same. My 17x7.5 rubbed because they had a smaller offset (40mm compared to 42-45) and wider tires (225). From what I hear, if you have at least 42mm offset and 215 tire, you're fine.
i am gonna get a huge lip on mine so my tires will actually stick out a lil and then when i get the wide body kit it willl look nice plus bye doin this i don't have to worry bout wheel rub jsut get a rim that has a good size lip on it so the rim is actually farther away i will prob get 18x8 if i can find some good ones but thats just a theory please tell me how stupid i sound if what i am sayin is garbage
your not counting the fact the they will rub on the inside of the wheel well when the car's tires are turned
Bomb Squad Unit #02
Yeah, when I put the 225 tires on (7.5 width rim) they came less than 10mm from the shock springs in front, and rubbed on the outside, so I worry what would happen to a tire on an 18x8 rim, cause you'll probably be running a 245 tire. Just my advice if ya want it.
