Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
tranny....NEED HELP ASAP!
Old Nov 20, 2005 | 01:05 AM
Lancerguy'03's Avatar
ok....eailer today car was hard to shift in and out of gears.....well tonight....the car wont shift into or out of gears when car is running. my thought is the trowout bearing....is this correct? i can turn the car off put it in 1st and start it up and it will drive in 1st....i can press the clutch in and push the gas and the car still accels....so im guess thorwoutbearing??? please HELP ASAP! i have a stage2 ACT, and lightweight flywheel....i have been hearing the "knock" from the thorwout bearing for some time now....can someone confirm my thought??
could it be cause of low fluid instead??? it shifts smooth when the car is off.
i did all the work myself to my car but i do not want to take the tranny to change the thorwout bearing again....so what is a good price to pay to have it done?
Old Nov 20, 2005 | 09:29 AM
bump
Old Nov 20, 2005 | 02:58 PM
bump for help...
Old Nov 20, 2005 | 03:01 PM
ambystom01's Avatar
Get the fluid replaced first and see if that helps. If not take it to a shop.
Old Nov 20, 2005 | 08:27 PM
bump
Old Nov 20, 2005 | 08:44 PM
WADADLIG_OZ's Avatar
did you change the TOB when you changed your clutch? How many miles on the new clutch?
WADAD
Old Nov 20, 2005 | 08:52 PM
yeah i changed thorw out bearing....and clutch has maybe 20000miles....but i drove from seattle to dallas 2 times on it....and that 2300miles both way....sooooo 15000 miles on clutch....and i dont race that much....and i never launch the car cause of gay wheel hop....and the clutch has had no signs of going out....been grabbing fine the past couple of days except for today.....my local friend told me to check the tranny fluid....casue i have a SMALLLLLL leak....but i guess its been more fluid than i though over time....so im checking it tommorw....and its leaking cause or my mistake i know where it is....i just need to re-seal it....
Old Nov 21, 2005 | 06:04 AM
morn bump
Old Nov 21, 2005 | 07:03 AM
rhyzin's Avatar
how bout your shifter rods? have they bent since dropping the tranny? when the engine is running, is the shifter stuck and can't move, or does it grind when trying to change gears?
Old Nov 21, 2005 | 10:00 AM
it grinds when i try to change gears.....it will come out of the gears w/ out grind (minimal grind....but u can definitly feel it)....but its hard....but forget trying to get it into gear....i would be considered a butcher...grinding everyone a pound...LOL.....but like i said when the car is off it shifts normal....
Old Nov 21, 2005 | 01:05 PM
rhyzin's Avatar
ouch. sounds like synchros. get a second opinion and try changing your tranny fluid. when you do change your fluid, look for debris and metal shavings.
Old Nov 21, 2005 | 02:08 PM
would synchros just ALL of a sudden go out?? or would ther be signs of them goin out? cause this happend just like BLAM!
Old Nov 22, 2005 | 09:42 AM
Not sure if this will help you but I was having trouble getting my car into gear after the clutch install.
The mechanic adjusted my pedal because he thought it may not have been properly disengaging the clutch. So far changing gears is much better although first gear is a little hard at times.
Can't tell you exactly what he did but he told me at the floor it was probably not fully disengaged.
WADAD
Old Nov 22, 2005 | 11:09 AM
i changed the fluid and got it suck outta gear....but same issue as before....ill go look at the pedel and see if somthing happend ther....the pedel feels the same thouhg....saying that the pressure plate feels ok....just doest feel like its disingaing the clutch...
Old Nov 22, 2005 | 12:11 PM
rhyzin's Avatar
if you look on the firewall, there is a circle thing that the clutch pedal hits. you can screw it up and down to adjust it.
and yeah, synchros can break all of a sudden, esp if fluid is low. but usually they wear down first.
