Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
B&M sport shifter
Old Aug 5, 2006 | 06:22 PM
Chizilds's Avatar
B&M sport shifter
so I installed the guy today. Decent install even though there is a TON of things you need to figure out on your own... horrible instructions. anyhow, i put it all back together and it seems to work fine with one problem. 1st gear is tough to find. Before, when I would have it in nutral i could push the stick right to left. Now it goes right the same but left is tight and super short. If you guys are going to need pictures I guess I can go rip it apart and figure it out for ya.
Old Aug 5, 2006 | 06:25 PM
ambystom01's Avatar
Give it a week, it might just need to be broken in. If it's still really tight and problematic, open it up and regrease everything.
Old Aug 6, 2006 | 12:35 PM
Chizilds's Avatar
I drove it more last night and it seemed a little better. man can you fly through gears! I just was wondering because there is not really any left play, but I can push it all the way right when in nutral.
Old Aug 7, 2006 | 05:40 PM
Chizilds's Avatar
fixed it... just needed to shave more off the secton that needed to be cut out. Ill post pics in a bit.
Old Aug 7, 2006 | 11:26 PM
CityKnight's Avatar
make sure youve applied enough grease at all the joints
joints
Old Aug 8, 2006 | 08:56 AM
Chizilds's Avatar
I just took off the center console, looked down at the shifter as I went through gears. I could see that the shifter linkage was smacking against the base of the shifter housing, I took a dremmel down there and sanded off the part it was hitting.... now its smooth as silk baby! no problems!
Old Aug 30, 2006 | 07:26 PM
Elvis's Avatar
nice. yeah i'm a little late but, how much and were for the short shifter. every place seems to have a different price.
Old Aug 31, 2006 | 02:59 PM
Chizilds's Avatar
$150 from a local store. 150$ is the price for the B&M that I found.
wiseguy9
12
Jun 21, 2015 11:59 AM
math399
Apr 30, 2012 01:18 PM
ukhky17
Feb 26, 2009 05:02 PM
rraulston
Jul 10, 2004 01:43 PM
