Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
reducing wheel hop?
Old Sep 16, 2006 | 03:16 PM
ManiakMik's Avatar
reducing wheel hop?
is there a way i can reduce the wheel hop coming out of 1st gear kinda fast??
Old Sep 16, 2006 | 03:19 PM
04lancerEsGuy's Avatar
NSC Engine damper or RRM Motor mounts
Old Sep 16, 2006 | 03:20 PM
Motor mounts will give u better results but they are kinda hard to install and more expensive so i suggest go with the engine damper.
Use "Search" ..... there are many threads on this topic.
Old Sep 16, 2006 | 04:02 PM
ambystom01's Avatar
Just doing the front mount makes a big difference, and the install is pretty easy.
Old Sep 16, 2006 | 05:40 PM
Grey_Fox's Avatar
I've had the NSC damper and solid motor mounts. The NSC damper was easy to install. The top didn't move as much, BUT the bottom still moved a lot and still had wheel hop. The solid motor mounts much more effective at putting the car's power to the ground. Don't get an engine damper for reducing wheel hop. Get or make your own solid motor mounts; they will keep the motor much MUCH more stable. You'll be a lot happier with the solid motor mounts, like I.
Old Sep 16, 2006 | 10:18 PM
ManiakMik's Avatar
thanks guys, i really appreciate it.
Old Sep 18, 2006 | 07:50 AM
03RallyLancer's Avatar
Deyeme Racing also carries motor mounts some what cheaper also
Old Sep 19, 2006 | 08:17 PM
ManiakMik's Avatar
are "drivetrain mounts" the same as motor mounts? bc on deyeme racing's site, they have "drivetrain mounts"
sorry for not knowin jakc
Old Sep 19, 2006 | 09:09 PM
yes they are the same
Old Sep 19, 2006 | 09:29 PM
narkus2's Avatar
Whiteline antilift kit works a wonder, and is cheap as chips!!
Old Sep 20, 2006 | 04:42 AM
crypto's Avatar
Former Vendor
i thought anti lift kits dont work on our car?
Old Sep 20, 2006 | 05:17 AM
Kurt's Avatar
Please share more information about the Whiteline antilift kit.
Old Sep 20, 2006 | 07:03 AM
it would be nice but it doesnt fit. at least not on the oz/ls... es owners are welcome to try since their suspension is closer to the mirage.
Old Sep 20, 2006 | 07:23 AM
HobieKopek's Avatar
IMO Deyeme is the way to go whether it's bought through RRM (assuming they still sell DMR mounts) or direct from DMR. Travis at Deyeme is easily one of the nicest guys in the game, plenty experienced, and their prices are very reasonable. The rear is a little annoying to install, front takes 10 minutes. Search for install info.
Old Sep 20, 2006 | 11:44 AM
RRM no longer sells DMR mounts.
