Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
problem with flywheel
Old Mar 14, 2007 | 01:04 PM
Carrier's Avatar
I have a fidanza flywheel and I have a problem...The bolt of origin are not long enough for bolter the flywheel...And as that they is bolts special, I am not able to find bolt longer.
thanks guy
Old Mar 14, 2007 | 01:43 PM
SLVROZ_03's Avatar
ARP makes flywheel bolts, but it's odd that a flywheel designed for the Lancer wouldn't work with the OEM bolts. Are you using the OEM bolts? or did they come with others?
Old Mar 14, 2007 | 04:03 PM
Carrier's Avatar
i use the oem bolt.... I would like to know if it already arrived with another lancer which uses the fidanza flywheel,,, But thanks for the arp bolt
