Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Help me please!!!!!!
Old Sep 15, 2007 | 09:23 PM
suggastik's Avatar
I jacked up my car on the cross member and the rear engine mount apparently was under some strain so it gave out and now my transmission is slipping could this be because the engine mount gave way? I have a 05 lancer about 28k miles. Please advise, I haven't gotten the mount changed as yet but i'm wondering if the mount could b the reason y the tranny is slipping whenever i try to move the car backward or forward
Old Sep 15, 2007 | 11:23 PM
lancerman360's Avatar
Huh?
Old Sep 16, 2007 | 03:00 AM
suggastik's Avatar
Let me see if i can explain it any better...Can a damaged rear engine mount cause my transmission to slip?
Old Sep 16, 2007 | 06:28 AM
evo_soul's Avatar
do you have a fault code? CHECK ENGINE light?
Old Sep 16, 2007 | 08:05 AM
c900t16's Avatar
what do you mean by slipping? As you give the car gas, the rpm's will rise quickly but your speed will remain the same? As if your clutch was slipping?
or do you mean its just not engaging properly?
Old Sep 18, 2007 | 04:08 AM
suggastik's Avatar
my check engine light comes on as usual then goes off. when i press the gas the revs build up and the car is barely moving and it happens in any gear i put the car in. its an automatic tranny
Old Sep 18, 2007 | 09:08 AM
BoostEEd's Avatar
Barely moving? or not engaging at all? Do you feel it engage when you go from N to D or R or from R to D? Anything?
First step in auto tranny diagnostics is to check the fluid level!
Did you check the fluid level? An auto trans will not operate correctly without the right amount of fluid in it. Too much and too little are not good things.
It could be as simple as your low on fluid and sucking air.
Old Sep 18, 2007 | 05:08 PM
suggastik's Avatar
thats the 1st thing i checked, the fluid level is good. when i put the car in D it goes forward but i have to give the car plenty gas for it to barely move and this happens with every gear i put the car in. it doesn't make sense to me since all other cars i had with transmission problems i would have to put them in L 1st then drive for a little while before i can put it in D. but my car now wont move regardless of the gear i put in it D,R,L nothing works normally
Old Sep 18, 2007 | 06:22 PM
JediBeavis's Avatar
Is the engine sitting at an unusual angle? It dosn't take much to get the fluid to move around, and it might show ok but that is because all the fluid is at one end of the pan.
Old Sep 18, 2007 | 06:42 PM
suggastik's Avatar
the car is on a level surface
Old Sep 19, 2007 | 06:09 AM
BoostEEd's Avatar
That sounds like serious slipage of the clutches. Which could mean the clutches are worn or there is not enough pressure in the lines to fully apply the clutches.
Many cars/trucks actually have pressure sensors that will generate a code if the main pressure is low, but I don't know about mitsu.
Have you heard any whining noises? That would indicate pump problems.
The other side of this is the torque converter. If you have a bad converter then you won't be turning the input shaft enough to cause it to drive.
There are many things it *could* be, pump, plugged filter, torque converter, worn clutches, stuck valve applying the wrong clutches.... and its hard to diagnose over the internet and with no codes its even harder. You might *try* and read the codes or get them read. There are many codes that won't throw on the MIL.
Not to ask a really stupid question, but your parking brake isn't on is it?
If your handy yorself there are a couple things you can do if you want to work on it. You can drop the pan and check the filter/screen (I assume its inside the pan on the mitsu tranny). You can get a pressure gauge and tap into the pressure test port and see what the line pressure is, though I couldn't tell you without a service manual where the port is and what the pressue is supposed to be.
It does sound like you have something going bad thats not going to fix itself, how many miles are on it?
Can you feel it apply the clutches to 'click' into gear at all?
Old Sep 19, 2007 | 06:12 AM
suggastik's Avatar
it only has about 28k miles on it
Old Sep 19, 2007 | 06:16 AM
BoostEEd's Avatar
I'd go get it warranteed then and not worry about it.
Old Sep 19, 2007 | 08:01 AM
blaze_125's Avatar
This calls for a dealer visit
Remember how they have the "best" warranty in the world?
Old Sep 19, 2007 | 01:02 PM
SLVROZ_03's Avatar
Yeah, you should be well within the 10 yr / 100k miles warranty! LOL
