Bad Clutch?
Bad Clutch?
My clutch was fine, nice and tight until i left it outside at a friends for a while when i was inside. I come out at the end of the night and the car is freezing (thanks minnesota) but the clutch is acting funny.
I push on the pedal with zero resistance until about 1/4 left in its travel, then it gets tight and I can shift gears...
Is this the slave/master cylinder? or the entire clutch in itself...?
I had the understanding if my clutch was going bad, My car would be slipping under acceleration, this is why I am wondering...
Thanks Ahead Of Time.
I notice it is getting very very hard to get my car into first gear from a dead stop. Second gear comes very roughly as well. Third seems fine, as well as fourth..fifth...
Any input is appreciated...
Yes, it does do it when the car is warmed up properly.
Also- Fluid levels, I'm unsure about, My initial reaction when this problem started happening was to check the level, I did, and I found that the fluid levels are below maximum, but not below minimum. Like I dont think I could add much even if i wanted too.
Any write ups on how to bleed the clutch?
Searched for about 10 honest minutes (lol) and found nothing other than the comparison to bleeding the brake lines...
Someone should write a complete clutch bleeding procedure! with pics!!!
Thanks for all the help anyway, I'm just carefully, carefully driving it right now, basically waiting for the time to come where i find myself stranded...
It's actually really not too difficult to be honest. I did it on my own but it took me forever until I didn't see any bubbles.
Thieves! It shouldnt cost that much. Last time I had mine done, I paid for $400 labor. My TOB/SC were $120 from the stealership. Plus the works evo clutch kit was around $400 as well. But for an OEM clutch, I think it would be a lot cheaper.
