Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
CVT sputtering
Old Feb 16, 2008 | 11:14 AM
dyno's Avatar
CVT sputtering
Has anyone else noticed the CVT surge when holding at a constant RPM? I get on the freeway everyday going up a slight incline. If I am accelerating, there is no surge. When I try to keep a constant speed and constant RPM, I can feel the CVT slightly let off and then "engage" again. On level roadways I don't notice it, only when going up hill.
Also in sport mode around 3000 RPM (3rd "gear" going about 30-40 MPH) if I give it a little gas the needle drops before starting to climb again. Of course this can be compensated by downshifting but I don't always like to have the needle rise above 4000 RPM. What gives?
Old Feb 16, 2008 | 12:33 PM
scorke's Avatar
You have a transmission that works in mysterious *** ways, thats what gives.
Scorke
Old Feb 16, 2008 | 01:39 PM
evo_soul's Avatar
D mode makes adjustments to match your desired speed with a fuel efficient gear ratio. Throttle position is one factor but also remember that the car learns your driving habits too.
Its had to say if you have a fault in your CVT or not, how steep is the incline, even a AUTO tranny on an incline will shift on its own to maintain speed or match itself up to driver throttle demand.
Old Feb 16, 2008 | 07:16 PM
BlueGTS's Avatar
most cars do "gear searching" when going up hill, especially if you live in the mountains.
Old Mar 22, 2008 | 12:39 AM
RC2099's Avatar
There is nothing wrong. Going up hill the CVT is under constant stress and is continualy working to maintain constant acceleration and speed.
When traveling in a straight line on level ground, the CVT acts like cruise controll. It adjust gear ratios and throttle input to maintain the current speed. This only happens when you hold the accel peddle in the same place. This is how is sames fuel.
Scott
DuffmasterFresh
Lancer Troubleshooting
13
Mar 31, 2018 05:05 PM
Bow87
Aug 31, 2017 09:47 AM
evo_soul
Lancer Engine Tech
20
Dec 15, 2009 02:01 PM
evo_soul
Lancer Engine Tech
16
May 26, 2008 05:34 PM
gggts
Lancer Engine Tech
21
Jan 23, 2008 07:17 PM
