Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Soft clutch
Old Apr 17, 2008 | 04:49 PM
HertMak's Avatar
Go buy a stage 2 clutch kit from RRM, problem solved, had mine installed last october, the guys that installed it wanted to bet me 10 bucks i'd stall it several times before i left the parking lot, which i did, and im not one to stall a stick shift, once it breaks in, one of the best clutches out there, enjoy.
Old Apr 26, 2008 | 08:14 AM
darkmitsu's Avatar
ummm, the reason they charge so much for a slave cylinder is because they put the slave cylinder inside the tranny bellhousing so you cant get to it unless you remove the tranny, witch is why they said replace your clutch at the same time. save you money in the long run... but 1000$ for a clutch job is rediculous, i did a n/t eclipse belts, radiator hoses, all tune up items, and clutch for 300$ labor ... he provided all the parts about 250-400$ in parts.
Old Apr 26, 2008 | 12:08 PM
Synthrocker's Avatar
Are you sure the slave cylinder is in the bellhousing? Looking up the labor times, All Data Pro sets it to be a 0.6 labor rate. I dont think youll drop the trans in a half hour =p and a clutch replacement is almost 5 hours labor rate. and there isent that much more to do after dropping the trans to replace a clutch. But if it is in the bellhousing and it really only pays .6, I'd hate to be the tech who lost their shirt on that job. I havent had to touch any of the clutch system in my car yet, so I havent really looked at it.
95% of Nissans the slave is outside of the Trans.
Only car I've come across with the slave IN the trans is the Focus ST Sedans.
*shrug* I'll see when I have to do it to my car =o
Old May 1, 2008 | 08:04 PM
ES_02's Avatar
i believe that the 06 lancers have it outside of the tranny while the 02-03 have it inside..... i may be wrong but it could be why it says the amount of labor for All Data Pro....
Old May 14, 2008 | 08:17 AM
JohnnyBoy427's Avatar
Originally Posted by Mark Hubley
Are you really that hard on the clutch that it was worth replacing at 10K miles?
He has 10K on an 03? WTF am I missing here?
kyoo
13
Sep 8, 2016 06:35 PM
vaflyboi757
Dec 18, 2015 10:27 AM
rherman_63
Jan 5, 2014 02:21 PM
grahamab
23
Aug 12, 2013 12:15 AM
enjoi1104
Jun 12, 2012 06:08 PM
