Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Auto Tranny "Slipping"
Old Oct 20, 2003 | 02:25 PM
hawkmoon's Avatar
has anyone found out the problem yet? my tranny is doing the same thing, usually if i'm driving in traffic around 20-25 mph and it shifts from 3rd to 4th. not all the time though. gotta get it to the dealer but kind of tough now to find the time with 2 jobs.
Old Oct 20, 2003 | 02:28 PM
bobaab's Avatar
i added more tranny fluid and it went away..for a while. but now it's back..i dunno why it's doing it..better get it checked!
Guru_Del's Avatar
so it is the 3-4 shift huh?
hmm that is using the HI-Reverse set of gears, my guess would be either the high/reverse clutch is slipping or the holding member (i believe it is a belt in our tranny) might either need adjustment or replaced (both warantee).
Old Oct 20, 2003 | 04:25 PM
nasdale's Avatar
I am planning on going to the dealer this coming weekend, I'll bring it up there and see what they say. I'll post with the results.
Old Oct 20, 2003 | 04:33 PM
azyan's Avatar
dam im joining the crowd now. just having it on D and drive normally, the RPM rev up to 4k while going 20mph like everyone else.
Old Oct 20, 2003 | 04:48 PM
WindsorLancer's Avatar
I hate to scare you guys, but my parents have a '95 Intrepid that I used to drive and it did the same thing. Of course this was after the warranty had expired and we had to get the whole tranny replaced. It was a while ago, so I can't remember exactly what the problem was. I know this is a different car/transmission but it sounds awfully similar.
Old Oct 20, 2003 | 04:50 PM
Guru_Del's Avatar
actually in today's world most tranny's arent re-built, they replace the tranny and send it off to be rebuilt. that way you get your car quicker and the dealer doesnt have to higher tranny rebuilders.
Old Oct 20, 2003 | 04:54 PM
azyan's Avatar
it just suck!!! might as well drop the AT tranny and this stinken SOHC engine *hint* = D
Old Oct 20, 2003 | 05:03 PM
Blue Oompa's Avatar
i had the same problem in my old car. there is too much pressure in the tranny and a cable is flying off. it was so bad in my old car that i had to trade it in for my current one. so get that checked asap and drain your tranny and fill it again. good luck hope it isnt as bad as mine was.
Old Oct 20, 2003 | 05:18 PM
skidd12's Avatar
i dnt know bout u guys but mine is still well, after a lot of pulling ebrakes and speeding up to 110.... hahaha but anyway, the other day some punks just poured mulch on my car..... pretty ****ty huh??? anyway, back to the topic amigos!!!
Old Oct 20, 2003 | 11:03 PM
Guru_Del's Avatar
mine is fine too and i am turbo on my auto. it sounds like either the clutch or band that holds your high/reverse drum is worn. or you have a fluid leak in that area, this would cause the car to engage in higher speed applicationd but not at lower speeds (as the valve body doesnt route as much pressure at lower speeds).
Old Oct 20, 2003 | 11:07 PM
eldanoloco's Avatar
Yeah Guru sounded right with the low fluid idea, have had that happen to me once. If not, just go to the dealer and tell it slips into Neutral about 3/4 way down the track, and theres no room for that ****.
Old Oct 25, 2003 | 03:41 PM
nasdale's Avatar
Okay, I went in this morning and had my tranny looked at. They drove the car around the block, could not "duplicate the complaint", and recomended I leave the car for a day so they can test drive (make the lunch run, etc.) the car multiple times to try to find the problem. I explained that this happens every blue moon, like over a month ago was the last time. I guess that they will see me later if it starts getting worse. I love warrenties!!! Good luck to everyone else, I will be scanning for any new info from somebody else, Thanks!!!
Old Oct 26, 2003 | 10:56 PM
Kebin's Avatar
i had the same problem in my cc lancer a couple of times. Took it to the mechanic and he said something about the transmission filter being blocked and another time there was no tranny fluid at all.
My mum crashed her corolla and after she got it back from smash repairs she had the slipping problem too, turns out no fluid watsoever. The mechanics reckon they put 4 litres of fluid in and yeh then where did it go? So i guess people with this problem should check regularly the transmission fluid levels for mysteriously disapperearing fluid or just change it more often as well as filters and the such.
Old Oct 26, 2003 | 11:11 PM
ozlancer0z's Avatar
this just happened to me today .. i was cruising @ 60 and and then i tried to accelerate a bit more it seemed to go into neutral on it's own. i didn't touch the shifter at all. i had my cruise control on and set if that makes a difference. but cruise only prevents u from going below the set speed right?
