Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Input shaft bearing help pls!
Old Sep 5, 2010 | 06:51 AM
Disappearingone's Avatar
First post so, hello, nice to meet everyone.
I just bought a 02 Lancer es, it sounds like the input shaft bearing is gone on it. The car drives and shifts smoothly so i dont think the transmission has any other problems outside of the rattling while the clutch is engaged or while the car is coasting in gear while the clutch disengaged.
So its obviously a bearing in the trany, and ill bet its the isb. Here is where i need the help does anyone know either what are the exact size and type of bearing the isb is or where i can buy a new one? i dont want to tear it apart till i have the replacements at the ready and i have searched all of the introwebs to fine a isb for the 02/03 lancer or the Mitsubishi F5M42! Can anyone help me out and point me in the right direction?
Old Sep 5, 2010 | 05:30 PM
senate6268's Avatar
The Mitsu part # is MD700207. You can purchase one from here:
http://www.mitsubishiparts.net/cart/?pn=MD700207
...or from the Mitsu parts department at your local dealership.
Old Sep 5, 2010 | 09:04 PM
Thanks i really appreciate the help.
Old Sep 5, 2010 | 10:03 PM
javicracer's Avatar
I have problem with that same ***in bearing, your input shaft will have play like a ****!
Old Sep 8, 2010 | 06:52 AM
blaze_125's Avatar
Input shaft? Or throw out bearing like everyone else?
Old Sep 8, 2010 | 08:51 AM
zulu989's Avatar
i have the same problem
Old Sep 9, 2010 | 08:29 AM
well, from my experience on other vehicles, the throw out bearing only makes noise when the pedal pressed in and the clutch is disengaged thereby causing the t/o bearing to spin. However i have seen them make noise only when the clutch is engaged due to the t/o bearing riding on the inputshaft thereby making a noise with the pedal out and not when the pedal is in. but the non evo lancers t/o is made on to the slave i think, so i would doubt thats whats happening.
Im still going to replace the all that anyway though.
Old Sep 9, 2010 | 05:06 PM
zulu989's Avatar
mine is not the t/o beaing, ive replaced that once before and even bought a new one this time. yet its still making the noise, can someone help with splitting the case, i have no idea and the manual aint helping lol
Old Sep 12, 2010 | 08:56 PM
zulu989's Avatar
ok the c clip is off that holds it in, all the bolts are out, the shifter part is out but i cant split it!!!!
Old Sep 13, 2010 | 08:02 AM
i dont know what to tell you
Old Sep 15, 2010 | 02:29 PM
mcgarvey's Avatar
Need to remove the extension housing and then use a gear puller to CAREFULLY remove the 5th gear synchro and driven gears. Make sure not to mix them up or lose the shims. At that point you will be able to split the bellhousing and main case. Most front drive transaxles work the same way- 5th gear appears to have been added on as an afterthought and complicates disassembly.
Old Oct 5, 2010 | 02:04 PM
ok, anyone know where to get the sealing plug by its self? the one i had to destroy to get to the C-clip off?
Old Oct 9, 2010 | 08:35 AM
mci2727's Avatar
I just got a new input shaft bearing on ebay for $12 shipped.
search the part number.
Old Dec 15, 2010 | 05:23 AM
bomber315's Avatar
how the heck are you guys getting that c-clip off of the input shaft? am i supposed to just tap it off the shaft and let it sit there or is there a tool that open it up and bring it up out?... please reply im about at my wits end, thanks
Old Dec 15, 2010 | 05:30 AM
bomber315's Avatar
here are some pics of my most recent headache
Attached Thumbnails Input shaft bearing help pls!-imag0144.jpg   Input shaft bearing help pls!-imag0145.jpg   Input shaft bearing help pls!-imag0146.jpg   Input shaft bearing help pls!-imag0147.jpg
