Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
transmission fluid
Old Mar 3, 2004 | 08:17 AM
kiran197's Avatar
transmission fluid
what kind of transmission fluid can i use i got an auto transmission the owner's manual spec. says DIAMOND ATF SP III but autozone sells mobile 1 ATF + 3 what can i use i got no clue about this ****
Old Mar 3, 2004 | 11:46 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Please keep in mind that responses on this forum don't always come in 8 minutes or less, and I doubt any thread needs a bump in the short of time.
I think the 2 oils you mentioned above are the same. Daimond is the Mitsu brand, so you won't find it anywhere but at a dealer. Just to be sure, ask the reps at autozone what kind of trans fluid they recommend (which would most likely be the Mobil stuff you mentioned). I drive a manual, so hopefully some auto guys will post here soon.
Old Mar 4, 2004 | 08:14 AM
kiran197's Avatar
thanks i asked a dude at autozone he recommened some chep stuff that said on the back on the bottle approved by mitsubishi and hundiy
Old Mar 4, 2004 | 11:58 AM
Moderator
Bomb Squad Unit #02
also, be sure to check the trans oil thread somewhere around here, it was about manuals, but someone did quote the service manual on changing auto trans fluid, and also a small discussion on the easy way which only changes some of it, and the hard way which flushes it all.
