Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
No clutch pedal after slave swap
Old Oct 26, 2015 | 01:22 PM
verticalspark's Avatar
I have swapped out the clutch and slave cylinder on my 08 ES. After going through an entire bottle of fluid trying to bleed the clutch I still have no clutch pedal. Every time I bleed the clutch I get no air but still no matter how many times I bleed it, there is no feel in the pedal.
I have done a good bit of research but I cant find a solution. I have tried to overfill and i have bleed the entire system a significant amount of time.
Old Oct 26, 2015 | 06:41 PM
hutch959's Avatar
where is all the fluid going? is it leaking out?
are you using a minivac?
Old Oct 27, 2015 | 03:44 AM
No, I have had a buddy sit in the drivers seat pumping the clutch. I have been bleeding it through clear tubing into a large plastic cup. Fill from the top, bleed the entire system until there are no more air pockets and still nothing.
I tired the overfilling trick but that didnt do anying.
Old Oct 27, 2015 | 07:09 PM
hutch959's Avatar
the pedal is very light... you sure its not working?
the guy that was pumping my clutch kept saying... "i got nothing".... and i was like ... no way!!
i got in the car and pushed it and was like... "no we good... that normal"
Old Oct 28, 2015 | 03:43 AM
100% its not that light. I got it after going through the whole bottle of fluid and checked it myself. Ill try to see if will disengage but the shop its sitting in has been closed the last 4 days. I finally have time to go back today and mess with it and will double check but if it does work that is the lightest clutch I have ever seen.
Old Oct 28, 2015 | 05:04 PM
hutch959's Avatar
haha... well, it is easier to push than the gas pedal....
anyway, if i had to guess, the master cylinder is not pumping enough to actually fill the hoses and the slave cyclinder... you probably still have air in the line.
will need a minivac to suck it through.
Old Oct 30, 2015 | 12:20 PM
Minivac did the job. But now the car won't start. Rechecking all plugs and check the clutch safety switch.
Well damn. All plugs are connected, after switch is good and still no start. Battery is new and has a full charge.
Kreeker
Aug 3, 2014 01:17 PM
detroit pistins
13
Dec 19, 2013 10:43 PM
Illrunya
Apr 7, 2011 01:03 AM
joosdawg
Dec 18, 2007 07:58 PM
woodc
Jun 16, 2005 06:46 PM
