Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Limited-Slip for an Automatic?
Old May 3, 2004 | 10:45 AM
KarlsLancer's Avatar
Does anybody make a limited-slip for our automacic Lancers? Ive seen one for the sticks.
Old May 5, 2004 | 10:16 AM
c'mon guys...is it possable or do I have to brake out the tig (j/k)
if not avaliable yet, how can I beef up the tranny?
Old May 5, 2004 | 10:31 AM
zlancer's Avatar
i don't think there is anything out there to beef up the lancer's auto tranny. unless you get custom made parts like a new torque converter and such.
Old May 6, 2004 | 03:50 PM
Guru_Del's Avatar
lsd wont fit.
you need to send your tranny to be built by a shop. there are no bolt ons available.
Old May 8, 2004 | 04:51 PM
4g94T's Avatar
that sucks
Old May 19, 2004 | 10:11 PM
lancerozr's Avatar
level10 makes a torque converter... but i recommend you find a shop that can correctly disassemble your tranny and rebuild it w/ the converter
- Rob
Old May 19, 2004 | 10:15 PM
4g94T's Avatar
how much will that cost
Old May 20, 2004 | 01:02 PM
IILANCERII02's Avatar
having an automatic is soo much more work
Old May 20, 2004 | 01:49 PM
bahamut's Avatar
First off, listen to some rational reasons.
Why do you need LSD for your auto tranny? For NA application, no one is going to spend enough money and tuning time to run a car 250 HP at the wheel. Manual is a bit different.
Does anyone actually know the cost of LSD? Around 600 smackers and more.
Higher stall TQ converters? Does anyone know the price of those things? Unless you have Huge displacement domestics, those TQ converters can cost as high as 1200 bucks!
Now the Q . . . do you have enough horsies to justify those high cost? Now, it's pretty self-evident.
Old May 20, 2004 | 03:55 PM
2BBoosted's Avatar
Yea level 10 just emailed me and said they have a torque converter and some hydromatic upgrade for autos. They say it will take of 1/2 to 1 sec off our et's if you can belive that. The torque converter is about 525.00 and the other i think was about 700.00 i think but check with them its posted in the ? will my tranny hold up
Old May 23, 2004 | 01:38 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Bahamut, an LSD isn't just useful for high power drag racing. It helps cornering as well, by keeping the tire that's on the ground moving. I can tell you from autocrossing a bone stock lancer with better tires that there's nothing worse than sliding sideways towards a wall of cones full throttle countersteering wondering when the outside tire will finally start spinning again. Of course, my car is lowered with sway bars now, helping to keep all tires on the ground and I cant run LSD in my class, but I'm just pointing out its other uses.
DSPORT
Aug 26, 2015 12:24 PM
kyoo
Apr 22, 2013 10:06 AM
chopdaddy
Jan 3, 2004 10:01 PM
Infinity
Nov 3, 2003 12:47 PM
Fred
Aug 29, 2002 10:09 AM
