View Poll Results: Best Shifter busings
Kartboy (even though they are only under the hood)
11
40.74%
ES
3.70%
LAncer shop (brass)
12
44.44%
LAncer shop (Poly)
11.11%
Voters: 27. You may not vote on this poll
Best shifter busings?
I bought the precision brand bushings when I bought my B&M Short Shifter kit from RRM. These bushings (I was told) replaced the 4 bushings at the base of the plastic shifter housing inside the car. Is this correct?
If I did that correctly, do you think I should also add the kart-boy under-the-hood bushings? Would they even be noticable?
- Jason
- Jason
there are bushings that connect the shifter cables to the levers on the tranny. They're located.... wait for it...... under the hood
Atually, "under the stock air box shifter bushings" might be a little more descriptive, but we just refer to them as under hood shifter bushings. There's a pic somewhere if you run a search on kartboy bushings. I would definitely recommend replacing the underhood bushings. Shifts are crisp, reliable, quicker, there's no play in the shifter when it's in gear..... 110% improvement
engineerboy: Nice. Thanks man. I even found an how-to install tutorial. I'll definitely add these since they're only $30, and I might as well go all the way if I've already installed the B&M and shifter-housing bushings.
- Jason
P.S. Do you know if I installed the shifter bushings from RRM correctly? They didn't come from B&M, so they weren't in the instructions. I called RRM and asked about them, and the guy on the phone was kinda vauge when he said "They're the bushings at the base of the plastic housing. So I took a logical guess and replaced the 4 rubber bushings that are located under the corners of the shifter housing..... is this correct?
- Jason
brass is a metal, urethane is a plastic
Seriously, there's a concern that brass might "wallow out" after a while and leave room for slop. Urethane might have the same issue, but I have more confidence in it's wear characteristics.... but that's me. Anybody else?
This is one of the easiest, cheapest mods in which you'll notice a night-and-day difference, more so if you're already installing a short shifter. I can't remember what the stock bushings and shifter felt like anymore.
Basically they make it crisper. I got the Kartboy under hood bushings and theres no more sloppy feeling in the shifter. Its solid and even makes that little click sound when it shifts. Mitsubishi should make a partnership with Kartboy so all lancers get these stock.
BTW, I have a set of Kartboy shifter cable and base bushings for sale. New, never install, $40 shipped to your door. Thread is here:
https://www.evolutionm.net/forums/sh...rtboy+bushings
Which is better?
