Karr Alarm
Old Dec 2, 2004 | 03:08 PM
frkypenguinboy's Avatar
Karr Alarm
Ok...I know this is not a Lancer specific question...but there always seems to be someone reading here that has an answer to any question, so I just have to ask!
The dealer installed the alarm and hooked it to my horn. I'm aware that the Karr alarms are capable of being hooked to an alarm siren speaker instead, which I want to buy and install...the issue I have is locating the point that they attached the alarm to the horns so that I can disconnect it and move it....
Any advice!?!
Thanks!
J.J.
Old Dec 2, 2004 | 03:11 PM
Tweak3D's Avatar
they probably used a relay to make the horn blair, try and find out where the positive wire is for the horn, shouldn't be too hard to find, but it should be tapped into somewhere and that will be your alarm positive. and the ground is just grounded to the frame. so disconnect where it is spliced and hook up your siren to that and you should be set. just find the wires hooked to the horn and try to follow them back. all I could really reccomend
-Justin
