keyless signals
Old Nov 22, 2004 | 07:44 PM
ozlancer0z's Avatar
keyless signals
My lancer came w/ keyless entry and up until a month ago, the signals would flash twice whenever i locked or unlocked the car. now when i use the remote to lock or unlock, no lights flash. i think it's weird because my signals work just fine when i use them to change lanes and my emergency signal works normally too. is anyone else's lancer having a similar problem?
Old Nov 22, 2004 | 07:48 PM
Kelmar's Avatar
Hold down the LOCK button for about 10 seconds, see if that does anything...
Old Nov 22, 2004 | 08:13 PM
ghostrider's Avatar
I think the manual might tell you how to reprogram the remote. That's what it seems like happened. I had mine programmed to not blow the horn.
ozlancer0z's Avatar
thanks .. i'm gonna try it out now
Old Nov 22, 2004 | 08:19 PM
ozlancer0z's Avatar
holding the lock button down for ten seconds didn't fix it .. i'm going to check the manual for any remote programming info
Old Nov 22, 2004 | 08:27 PM
ozlancer0z's Avatar
ok fixed it .. hold the lock button down for 4-10 seconds and then press the unlock button (while the lock button is still being pressed) ... and that should switch it from each mode
Old Nov 22, 2004 | 08:28 PM
psionic98's Avatar
make sure all your doors are shut properly.. I noticed that if one of the doors was just slighly ajar it wouldnt flash or horn, but it would still lock the doors... maybe one of your door sensors is out
Kelmar's Avatar
OOPS! Sorry, I meant to type that part, sorry.
Old Nov 22, 2004 | 11:58 PM
ozlancer0z's Avatar
yeah it's a really tricky process actually ... i'm glad the manual gives me clear idea of what to do. thanks for the help anyway though
Old Dec 1, 2004 | 04:31 PM
frkypenguinboy's Avatar
The weird thing...that JUST happened to me the other day....but it corrected itself. Then, it did it again and wouldnt' correct itself...so I got under the dash and messed with the wiring...all better!
Old Dec 1, 2004 | 05:36 PM
Blacksheepdj's Avatar
Dude, what page is that!!??!?!??
Now I know what I'm doing tonight!
Old Dec 4, 2004 | 10:47 PM
It happened to ME again tonight! I think it must be something different than what you guys are talking about....I just locked and unlocked a few times and it started working again.
Strange.
unicycle
Aug 20, 2016 08:25 AM
jimbo74
Lancer Troubleshooting
Jan 3, 2015 06:49 AM
xisplo
Aug 14, 2011 03:53 PM
voidhawk
Aug 2, 2008 02:21 PM
lilman8403
Feb 3, 2006 10:36 AM
