Determine Door Lock Status
Old Aug 1, 2008 | 02:38 PM
voidhawk's Avatar
Question Determine Door Lock Status
Hi guys, I need some help finding a wire on the stock keyless entry system that I can use to determine the state of the door locks (locked/unlocked). Does anybody know if there's a point where I can pick up a 12V signal that indicates if the car is locked?
Or if that's not available, where can I pick up a momentary for whenever the locks are being triggered to either lock or unlock?
Thanks.
Old Aug 2, 2008 | 09:48 AM
biggie5252's Avatar
You can find the triggers in the doors. As far as a status signal stating whether or not the doors are locked or not, I don't know. There might be something at the keyless system itself, but I think of what it'd be used for. What are you trying to do?
Old Aug 2, 2008 | 10:06 AM
voidhawk's Avatar
thanks for the lead! I want to turn on an LED scanner whenever the the ignition is off and the doors are locked. The IGN signal is easy, but I haven't figured the door locks yet. I know it would be simple with an aftermarket alarm, but I'd like to keep the OEM system.
Old Aug 2, 2008 | 10:48 AM
biggie5252's Avatar
You could get some kind of latching relay that would be triggered by the door lock pulse, stay latched while the doors are locked, then unlatch with a unlock pulse. I'm not sure how that would work if you manually unlocked the doors though.
Old Aug 2, 2008 | 02:21 PM
voidhawk's Avatar
yes that is my backup plan in case I cannot find a signal for locked/unlocked (just the trigger). Thanks for all the suggestions though!
UnholyMaggot
Jul 21, 2019 09:53 AM
maciekish
Apr 28, 2008 02:10 PM
mazdryk
Mar 27, 2006 07:18 AM
lilman8403
Feb 3, 2006 10:36 AM
WRC4ever
Jan 29, 2004 08:31 PM
