Exhaust leak and leak and leak
Old Jan 18, 2005 | 04:58 PM
Blacksheepdj's Avatar
OK, I bought an RRM header used. Just looking at it, the black deposits showed an exhaust leak. It was at the rear of the header/downpipe connection.
I thought nothing of it and installed. After firing it up, the RRM header and Buschur downpipe had a huge leak. Same spot. So I removed the downpipe and put the stock one back on (because I'm selling the Buschur DP, in case you were wondering). Still leaks. I haven't removed anything, but the header/downpipe connection is the problem again.
Could it be the header? Or am I just hooking something up wrong everytime?
Old Feb 22, 2005 | 06:55 AM
Al Banks Holla's Avatar
Check your gasket. maybe it's time to replace the one you have in there now?
Old Feb 22, 2005 | 06:56 AM
Been through a few, actually.
Might try a higher-quality next time, though.
Old Feb 26, 2005 | 08:57 PM
Dookie's Avatar
take the header off and take it to a machine shop. The flange is most likely warped and slowly eats through gaskets like you said you replaced already. If the flange is warped nothing will stop a leak. Had mine resurfaced and all is good. I also invested in some copper gaskets so no more blow outs for insurance. Look for the 2 1/2" inner diameter ones that SCE makes. You need to ream out the two mount holes a little to make it fit but other than that-no problems!
Old Feb 28, 2005 | 02:16 PM
Thanks - I might try that with the header and the gasket.
Old Mar 30, 2005 | 07:58 AM
JustJester269U's Avatar
Question
Did you use any copper sealant?
Old Mar 30, 2005 | 02:53 PM
Went back to stock header/DP for the partout (see my sig). But I have another exhaust leak, of course. I think I'm just cursed.
Old Mar 31, 2005 | 08:44 AM
leaks...
If your leak is at the seals than you need to get a new sealing plate(I can't remember what they are called) to go between the upper and lower parts of your headers and a tube of copper foil sealant. Put the sealant on all three parts of the header as you bolt it back on. make sure you get any gunk off that might be there before you add the copper seal.
