Help Please!!!!
Old Mar 9, 2005 | 09:03 PM
Aroz's Avatar
Unhappy Help Please!!!!
Can anyone help me with this problem...Here's what happened:
I first started cleaning the engine with a little soap and water, then I wiped the engine down, clean and dry. Next, I started to remove my CD deck and the climate control panel to color match my interior lights (all red). After that, I took the center console off and changed the ciggarette and ashtray lights to red. I changed the blue gel cap covers to red and replaced everything back to its original place. When I started the car and put my CD deck back, I noticed that the clock, my dome light, my CD deck, my power locks didn't work anymore...Does anyone know what has happened to my car?????...The good thing is that the lights I replaced is working. Please help me...Thanks.
Old Mar 9, 2005 | 09:05 PM
petey pab's Avatar
did you check the fuses?
Old Mar 9, 2005 | 09:06 PM
Z_Lancer_Man's Avatar
I can think of two things. Check the fuses behind the dimmer switch underneath the dash there and see if any are blown. Also, check the fuses in your engine bay. You may have inadvertantly blown a fuse with water getting somewhere it shouldn't be. So, check all the fuses and then get back to us.
Old Mar 9, 2005 | 09:07 PM
DfWeVo's Avatar
I did something similar and it was a fuse in my engine compartment... check them all
Old Mar 9, 2005 | 09:17 PM
irulea2's Avatar
Sorry this is off topic, but how exactly can i clean/wash my engine. Can I just go to one of those self car washes and just spray engine, I'm not sure but I think that wouldn't be good, someone please let me know.
Old Mar 9, 2005 | 09:48 PM
I wash my engine every two weeks. I usually spray it down with simple green, then I spray it off with water after a couple of minutes. Just don't spray the alternator if you can help it - and you can try to avoid the battery and fuse box some. Otherwise, you can spray it down no problem.
Old Mar 9, 2005 | 09:59 PM
irulea2's Avatar
do i need to let the engine cool down b/c I need to drive to a car wash?
Old Mar 9, 2005 | 11:22 PM
If you're just driving to the wash and haven't driven it much else, then you should be fine, be careful spraying the exhaust manifold/header first though, since its still really hot. Otherwise, it wouldn't hurt to wash the rest of the car first, letting the engine cool down, then clean the engine.
Old Mar 9, 2005 | 11:32 PM
irulea2's Avatar
thanks, just wanted to make sure. The weather is gonna be getting nice here so I will finally get a chance to wash my car really nice, it definately needs it inside and out.
Old Mar 9, 2005 | 11:38 PM
lookslikeanevo's Avatar
it is the fuse inside the engine bay, in the fuse panel uns=der the yellow thing, ill tkae a pic tomorrow...
Old Mar 9, 2005 | 11:51 PM
here you go, inside the yellow thing
Old Mar 10, 2005 | 01:28 PM
Aroz's Avatar
Hey lookslikeanevo....thanks for the info...you were right. It works now...Peace!!!
logic
48
Feb 27, 2026 07:19 AM
kericr
14
Dec 15, 2023 12:28 PM
4G63kevin
14
Apr 9, 2010 08:54 AM
ohfourLancer
12
Mar 30, 2007 07:15 AM
2BARevo
15
Sep 24, 2005 01:11 PM
