camber problem
Old Mar 23, 2005 | 05:34 PM
risingsun's Avatar
camber problem
Has anyone else noticed a positive camber problem on stock suspension?
I have noticably more wear on the outside of the tires than that on the inside it's on both fronts, so it shouldn't be an alignment problem. I bought new Falken tires after I purchased my car in January of 2003. Rear wear is normal.
also, would lowering with the RRM springs help or make the prob. worse?
Old Mar 23, 2005 | 05:46 PM
maxum17ft's Avatar
lowering springs would help if you have pos. camber, wow, your lucky. with my stock susp. i had neg. camber and now its like 30 times worse, so i bought a camber kit, and i still have neg. camber
