engine idle problem???
Old Apr 5, 2005 | 05:13 PM
krnzzang84720's Avatar
My lancer oz is starting to give me a problem..
currently i have rrm header, test pipe, intake, and exhaust...
i just installed new spark plugs. NGK with .044 gaped...
So this is the problem.. when i start the engine i hear from exhaust that my engine is misfireing and shaking... so i softly gas it to raise rpm but then my engine don't rev. After 3min everything is okey!!! somebody please help me
Old Apr 5, 2005 | 07:23 PM
bump... help
Old Apr 5, 2005 | 07:27 PM
lookslikeanevo's Avatar
check your coils, and pull the plugs and see if they are fouled...yes i know you just replaced em.
Old Apr 5, 2005 | 07:47 PM
I THINK it's my wires,, i have manacore ones but I think i am going to replace it with stock and see what happens
Old Apr 6, 2005 | 09:00 AM
frchgl123's Avatar
I don't know if it will help, but I also have the magnacore wires and have noticed that sometimes if you put your hood up in the dark (garage or at night away from lights) you can see a spark jump out of the wires! WTF?! be careful about adjusting them with the car one b/c that spark has a little bite to it. But yea, check that out b/c sometimes if can make the car feel like it is misfireing, or cutting out while you are driving. Plus try some of that elctro-grease(or something like that) from any autopart store. Little package of it cost like 70 cents. But good luck, don't forget to post what happens when you put the stock wires back on.
Old Apr 6, 2005 | 03:46 PM
ok I have putted stock back and same thing, I don't get miss fire while i am driving, ONLY at very first when my engine is in idle. I have RRM header and my engine light is on. I just went to the autozone and got the light checked and it reads something like high voltage, Too much air flow. So does anybody have this problem with RRM header??
Old Apr 6, 2005 | 03:53 PM
Alchemist's Avatar
you sure the gap is right? 0.44 sounds big. Shouldn't is be like 0.42-0.40 That could be causing a weak spark and only after a few minutes of stumbling is enough heat stored in the engine to help ignite the fuel with these weaker sparks...... just a thought.
Old Apr 6, 2005 | 04:25 PM
i don't think it's spark plugs,, it is either with o2 sensor or something with fuel!!! somebody help!!
Old Apr 6, 2005 | 04:31 PM
o2 sensor?....wouldnt causy your car to run lean, or misfire unless but am not sure, its th e 1st o2 sensor, the second one wont pu it in a closed loop....if its fuel, then drive around till its gone fill and start aLl over again
Old Apr 6, 2005 | 04:34 PM
Alchemist's Avatar
O2 sensor hasn't a damn thing to do with spark. you're basically telling us you don't know jack about engines, tuning, etc. and then telling us we're wrong without checking. Nice.
Go get the dielectric grease from the parts store and lubricate the ends of the plugs, the connections between the wires and packs and try again. Double check that gap, too.
And blinker fluid might help.
Old Apr 6, 2005 | 04:38 PM
haha i love it....i was gonna be an *** but i waited.
Old Apr 6, 2005 | 04:39 PM
i don't know lot about engine but i do know how it runs and work. what i said was because of miss reading of my o2 sensor i might not be getting proper fuel.. and i know it not the spark plug since i only get the misfire at the beganing, just for first 2 min of my engine start..
Old Apr 6, 2005 | 04:45 PM
what is very weird is that only at the beganing. just 2-3 min then it's fine. At the first 2-3 min. i heard misfiring and my mufflar sounds rough.
Old Apr 6, 2005 | 04:50 PM
how do you know your o2 sesnsor is miss reading?....thats has nothing to do with fuel delivery...
Old Apr 6, 2005 | 04:57 PM
ok... what do you guys thing the problem is then?? help!!!
