Fuel Pump not pumping
Old Apr 20, 2005 | 10:01 AM
SandmanMS's Avatar
Exclamation Fuel Pump not pumping
Today hasn't been my day. After leaving the doctor's office I come out to my lancer to find that it won't start. It turns over and attempts to start but there is no fuel getting to the engine. I listen closer and hear that my fuel pump (the one from the RRM turbo kit) is not pumping. I am going to try and force-drive the pump as per the service manual and if that works then check the fuel pump relays and MFI relays. I was just wondering if any of you could think of anything else to check if it doesn't happen to be any of those four componenets? Thanks.
Old Apr 20, 2005 | 11:31 AM
Guru_Del's Avatar
Sure try this.
Pull the seat off, take out the 4 screws unhook the line that is the press fit. Next have someone turn the ignition on to the on position if it gushes gas you are good, if it only sprays alittle then you got a loose pump. pull it out and make sure it is pushed up into the housing all the way.
Old Apr 20, 2005 | 12:15 PM
Kelspar's Avatar
Wow so the RRM kit comes with a fuel pump too?
Old Apr 20, 2005 | 12:27 PM
Guru_Del's Avatar
yes the rrm kit comes with a larger fuel pump. their kit comes with every little thing you need to install and get running.
Best kit i have ever seen or owned
Old Apr 20, 2005 | 12:31 PM
Kelspar's Avatar
Lol well i am now the proud owner (not yet received) of a non-ic kit. hoping ot upgrade to ic when i get the funds. Hoping to go semi custom (piece together) so maybe i can save some money.
