stuck in the rain
Old Apr 30, 2005 | 10:46 PM
BigP436's Avatar
stuck in the rain
whats up guys, ive been havin a problem latly with my 02 lancer es. whenever it rains and for the next few days when i have the heat on, im gettin water into my heater box and its hittin the blower fan and leakin all over the pass. side carpet. now heres the funny part, the blower has to be on, and it only leaks when i make a hard left turn.
ive taken the whole heater box setup apart and dryed it, cleaned out the drains in the vents below the windshield but im still gettin the same problem. ANYONE with a suggestion on what my problem would be, i would appreciate your $0.02 on tryin to fix this.
Thanks,
Pat
Old Apr 30, 2005 | 10:49 PM
Z_Lancer_Man's Avatar
Just curious, but have you contacted your dealership? Sounds like something that could be covered under warranty.
Old Apr 30, 2005 | 10:51 PM
BigP436's Avatar
no, i havent taked to them yet, but i have no warrenty, bought it used
Old Apr 30, 2005 | 11:01 PM
Ah, that sucks, have you been able to see where the water may be entering?
Old Apr 30, 2005 | 11:04 PM
BigP436's Avatar
na, i have no idea where its comin in, i had the majority of the dash apart the other day after work and i couldnt find where it was comin in. the whole situation is drivin me nuts, only problem ive has w/ it in 55,000miles (knock on wood)
Old May 1, 2005 | 01:30 AM
gregivq's Avatar
Your evaporator is leaking. I think it's a common problem with Lancers. Check in the troubleshooting section in Us Lancer section. Either it's the evaporator (expensive) or something else (dirt and leaves stuck under that plastic thing below the windshield).
Go to your dealership, they will know for sure!
Old May 1, 2005 | 09:15 AM
BigP436's Avatar
thanks a lot man, ill look at the evaporator today to see if thats my problem
Old May 1, 2005 | 12:36 PM
rcefstsfecr's Avatar
My mechanic was telling me that to replace the evaporator it was going to be close to like $800. It's underneath the dash and it's alot of labor to get it out/put it back.
Old May 1, 2005 | 03:49 PM
gregivq's Avatar
tsb No: 035508
Summary: debris ( such as leaves, etc ) entering the front cowl area may clog the evaporator housing drain tube. If this occurs, the evaporator housing may fill up with condensation and overflow into the passenger compartment, and into the blower motor.
Few other member had this problem and they got it fixed. It didn't cost much and your dealer can do it for sure. They do know this problem exists and they will fix it.
Believe me I had a similar problem (not the same) and did a lot of research since my warranty is expired and I didn't want to pay someone to fix it.
Midas told me it's evaporator and it's going to be $800 to fix it. I did some research spend $5.00 on a tube of glue and that's about it. But like I said my problem was different.
Do your homework because you don't want to buy a new evaporator for $800.00 and have the same problem.
Old May 1, 2005 | 07:30 PM
BigP436's Avatar
i looked into it today and it turned out that the tube was cloged, not to bad of a fix. thanks a lot guys
Old May 1, 2005 | 10:00 PM
Glad to hear it was a simple fix and didn't have to go and get raped at the dealership.
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
stealthlancerOZ
52
Sep 19, 2014 10:17 AM
atxevoxmr
Dec 7, 2013 10:44 AM
cali11b
Apr 27, 2011 07:35 AM
BigP436
May 1, 2005 01:26 AM
