idle problems
Old Feb 21, 2003 | 05:05 PM
ozrmrlancer's Avatar
idle problems
When I am at a light my idle goes to 1500-2000, then drops down almost to the point of stalling, then goes back up, then finally stalls. My mitsu dealer won't look at it cuz the check engine light is not on. I just think they are a bunch of dicks. Any way this problem only occurs when the cars warm, and about once every other day. Can anyone give me some feedback?
Old Feb 21, 2003 | 05:10 PM
HobieKopek's Avatar
First off...this does not belong in show and shine. Second, several people have had precisely the same problem which you could have found answers to if you'd taken the 2 minutes to run a search and glance over the results. Third, if you don't tell us what mods you've done to your car (I'm assuming it's just an intake that's causing this) then it's next to impossible to diagnose.
EDIT: Forgot. Most likely you can remedy the situation by resetting your ECU. Just disconnect the battery for 15-20 minutes.
Old Feb 23, 2003 | 06:06 PM
thanks
Evo4walshy
Feb 10, 2017 06:47 AM
Streetsfam
Mar 29, 2016 05:01 AM
alpix715
Aug 30, 2010 03:13 AM
hotredevo
Jul 29, 2010 06:54 AM
jenx1976
Dec 17, 2007 05:32 PM
