need some help installing strutbar
Old Feb 22, 2003 | 10:36 AM
Epidemic's Avatar
Hey guys! I have the RRM K-bar, and i am having a problem. When i try to get it on it lines up alright, but when u look closely the screws are not lined up with the holes in the bar. So when i try to screw on the nuts they don't grab onto the screw. Is there something i can do to fix this. I can get 2 of the screw on, the top right one and the left lower one. Any help would be appriciated.
Old Feb 22, 2003 | 10:45 AM
TooFastOZ's Avatar
I wish I could help bro..that "Try this" link is freakin funny though! i was laughing my *** off, late!
Old Feb 22, 2003 | 11:05 AM
ROCK's Avatar
Call us today. We can give you some tricks.
ROAD/RACE
http://www.roadracemotorsports.com/
Old Feb 22, 2003 | 11:36 AM
Epidemic's Avatar
Thats why i love RRM, always willing to help. Thanks rock i will call in about an hour or two. Shop with RRM guys, only company i know that actually gets back to their customers.
Old Feb 22, 2003 | 01:45 PM
Sten's Avatar
Place the bar in place with two holes firmly in. Take rubber mallet or use hammer WITH CUSHIONING TYPE MATERIAL like cardboard. tap gentle on side that just barely fits. It will tap down into place. Screw on nutz firmly..
That's how I got mine on.
Old Feb 22, 2003 | 01:55 PM
ghostrider's Avatar
Was about to say same thing, just put a towel over the side you can't get and hit it with a rubber mallet. I had to do that with my RMR strut bar to get the other side in place. Another option would be to lift the front end of your car with a hydraulic jack so the bolts line up better.
Old Feb 22, 2003 | 03:37 PM
Epidemic's Avatar
I tried it all, to no avail ..... i think its just a bad strutbar. I will ask rock if he will change it out. ROCK pm on here and tell me about your return stuff. I am still trying tho
Old Feb 22, 2003 | 04:57 PM
LaNceRiTiZ's Avatar
....try jacking up the car....
then step down on the tires...
the screw should go down ...and just line up the k-bar
to the screw...then do the other side...
that's what i did w/ my RMR strut bar
Old Feb 22, 2003 | 05:36 PM
bobaab's Avatar
hey dood, i had the same problem..but luckily, my dad is a "dental technician" (not a dentist, but he makes crowns, bridges, etc.) so he had a grinder thing and i cut part of the screw. i trimmed the side about 1.5mm, and that worked right away.
if you've tried screwing them in too many times, they could be busted so u should check that too. and if all else fails (which i hope it won't) call Rob and he'll go through everything with u
good luck!
-Bob
Old Feb 22, 2003 | 05:53 PM
Epidemic's Avatar
I tried that too, i grinded the screw all the way down to the main screw part. The problems is that the alignment is so far off that i can't get the socket in between the nut and the edge of the bar.
Old Feb 22, 2003 | 11:14 PM
bobaab's Avatar
hmm a picture would be helpful, but installing a strut bar shouldn't be THIS hard..it could be a faulty strut bar
contact Rob..he's got the best advices
-Bob
Old Feb 24, 2003 | 08:45 PM
OZBOTS's Avatar
Post
I agree with Lanceritiz I did the same **** with my RMR.
Old Feb 24, 2003 | 09:03 PM
Epidemic's Avatar
It's raining ice out here, but when it get sunny i will try again and try to take a pic.
Old Feb 24, 2003 | 09:10 PM
redbeard's Avatar
When you say grinding the screws, I hope you mean the bolts. That is what I did, file down the washer part of the bolt. You can also try having a friend bend the "k" part of the bar a little to help the screw line up over the hole, then try to fit your socket in. You could also try getting a thin walled socket, or even sand yours down. Good luck.
Old Feb 24, 2003 | 09:15 PM
Epidemic's Avatar
sorry, yes i meant the bolt. i did file down the "washer" part of it. I had 2 strong guys bending the bar while i was trying to screw it in. I went to almost 4 auto and hardware shops and there were no thin walled sockets (which i what i really really needed), all the sockets were the same width as mine. I went to a local shop "Top Notch Performance" and they said they would fix it for 45 bucks . I almost went off on their a**. GRRRRR. Anyways i am just gonna wait until i gets warmer and hope i can get it fixed without sending it back to RRM.
